Author Topic: fitting an electric blind  (Read 2893 times)
V6karl
  • Woking,surrey
« on: 17 April 2007, 22:23:13 »
Hi ya u guys,i thought id  throw another question to you all! A couple of weeks ago i found out im becoming a dad again  so would like to find out How hard is it to fit a rear electric blind in,well you got to show them that you are doing your bit haven't you ?Going back to the subject in the boot their is a black plug is that what the blind plugs into?????Any help on this subject would be truly appreciated
Re: fitting an electric blind
« Reply #1 on: 17 April 2007, 22:29:29 »
You need the parcel shelf as well as the blind itself.
Easy enough to fit, though takes a while due to amount of trim to remove...
The blind electrically just plugs in, and put switch in dash - all wiring tends to be in place.
tanker12uk
  • Saltburn by the Sea. Cleveland
    • Elite 3.2V6 2001
« Reply #2 on: 18 April 2007, 02:22:02 »
I was going to do that on my old gls but found that the wiring had been knacked by the met when it was a plod car so bought an elite with it if point is I have a blind and shelf in my garage if you cant find one I am open to offers on it
nixoro
  • Hitchin, Herts
« Reply #3 on: 18 April 2007, 15:07:20 »
Karl congrats on the news.
If you can find a rear shelf to fit its pretty simple.
Firstly check you have cable with a square connector hanging down somewhere on the left hand side at the back of the boot it maybe covered by the boot trim.
This is how I fitted mine.
1. I flattened down the back seat.
2. Release the rubber from around the hole.
3. Pull the rear headrests out from the rear shelf, then twist the central pin off this is what the armrest back locks onto.
4. Using 2 flat bladed screwdrivers one either side of the grey inserts, push in the tabs to release the insert which the headrest arm goes into. (x6 inserts) do not push the tabs in too far as they may snap.
5. There should be a few push in fasteners holding the shelf in position using again a flat bladed screwdriver hook these out, these are usually not seen when the seats are in use. Row of 5 or 6.
6. Remove the cover to the centre seatbelt unit.
7. Using a (19mm socket?) with an extension bar remove the single bolt holding the seatbelt
unit in place.
**Now all the pieces should be clear to pull the shelf out**
8. Push in the new shelf with the blind gradually into position as you need to feed the cable through the top in through one of the holes so that its seen in the boot.
Once the shelf is back in place, push back in the fasteners and the headrest inserts then the headrests, connect the cable up in the boot and put the switch in place.
With mine I didn't need to do any fuses it just worked. Plug and play as they say.
I'm not sure if there is an official guide with photo's but this should give you some idea of what is involved.
HTH
« Last Edit: 18 April 2007, 15:26:48 by nixoro »
chris-b
  • Wirral
« Reply #4 on: 18 April 2007, 21:10:41 »
Got a shelf here you can have foc if you pay the postage,
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #5 on: 19 April 2007, 02:04:38 »
If Karls not interested let me know.  :y
gizza
  • baildon essex
« Reply #6 on: 19 April 2007, 08:35:18 »
im after one for my 1997 omega if any one else has one
ClarCE
  • Newbury, Berks
  • Cam Covers x 5
« Reply #7 on: 19 April 2007, 09:31:54 »
Me 3!
So Far - :: Re-Finished Elite Wheels :: Black Leather Interior :: 3.0 Cams :: Chipped (REMOVED, EBAY SHI*E) :: Facelift Skirts ::
To Do   - :: Facelift Rear Bumper, Door Mouldings :: Irsmsher Front Air Da
