Coolant level decreasing
Started by eyad, 17 April 2007, 01:50:37
Being a hot country, the pool of water isn't condensation from A/C condensor, rather than related to your coolant loss?
Aircon condensers get hot, not cold, its the condensator that gets cold....
Can you tell us which side the leak is on......as viewed from the front of the car
eyad
i guess i will need closer look and check radiator.
thanks a million.
eyad
well , the pool on the radiator is on the right hand side standing in front of the car. not sure about the left side since radiator is covered a many plastic part.
the lower hose is on the lower left side , where i found some wet traces of coolant ( antifreez)
old cruiser
It could be the radiator to lower pipe joint that's weeping then, in which case it might be worth checking tightness of the clip and or replacing with new Jubilee clip and see how it goes.
Cheers Pete
