Author Topic: Sunroof Motors  (Read 4961 times)
nixoro
  • Hitchin, Herts
Sunroof Motors
« on: 18 April 2007, 08:30:31 »
I need to find a decent Motor + Sunroof panel for my dads Omega.
I have noticed his being a 94M with the red dome the twist dial has the pin fixed to the dial, so you pull the dial from the roof with the pin
Mine being a 97P has the panel without the red dome and the twist dial pulls off the pin coming out of roof leaving the centre pin still attached to the sunroof motor.
Can anyone tell me if the earlier and later sunroof motor have the same connector as I am thinking to source a sunroof motor from a later omega, as the last time I had the sunroof panel off on my dads I managed to pull half the sunroof motor from the roof and me being me couldn't understand why the pin would not come out of the twist dial and so it got butchered.
Hope this makes sense.
nixoro
  • Hitchin, Herts
Re: Sunroof Motors
« Reply #1 on: 18 April 2007, 08:57:24 »
Any help on this would be much appreciated as my dads omega has half the sunroof twist dial missing at the moment. Sunroof still opens and closes fine.
snappa
  • London
  • when`s payday
Re: Sunroof Motors
« Reply #2 on: 18 April 2007, 11:08:05 »
I think i have one lying around at home somewhere if its you are welcome to it, cover & dial
nixoro
  • Hitchin, Herts
Re: Sunroof Motors
« Reply #3 on: 18 April 2007, 12:21:21 »
Cheers Snappa
Just trying to suss whether the sunroof motor connectors changed at all cos if they are the same on the early aswell as the late models then I would go for one of the late models sunroof motors which has the pin sticking out of it with the push on dial.
Snappa if you have the motor too could you post up a piccy.
Hope that makes sense
« Last Edit: 18 April 2007, 12:21:52 by nixoro »
snappa
  • London
  • when`s payday
Re: Sunroof Motors
« Reply #4 on: 19 April 2007, 11:44:21 »
You should have mail
snappa
  • London
  • when`s payday
Re: Sunroof Motors
« Reply #5 on: 19 April 2007, 13:08:25 »
Here goes
nixoro
  • Hitchin, Herts
Re: Sunroof Motors
« Reply #6 on: 19 April 2007, 14:44:35 »
Cheers Snappa
I shall check tonight whether it will fit should think so same design, just wondering whether the cable connections will be the same.
Guess I could try my dads in mine :-/
last time I removed the sunroof panel in my dads omega I managed to pull the black cover part on motor along with the circuit board. All seemed to come a one piece.
What year was the car it came from?
« Last Edit: 19 April 2007, 14:54:21 by nixoro »
snappa
  • London
  • when`s payday
Re: Sunroof Motors
« Reply #7 on: 20 April 2007, 09:23:56 »
Sorry mate don't know what year it came from
nixoro
  • Hitchin, Herts
Re: Sunroof Motors
« Reply #8 on: 20 April 2007, 09:48:40 »
No worries. :y
Unfortunately I still need to double check it will go in my dads car plan is to remove the one in my dads car and connect it in mine to check the cables/conector is the same and that it will work on my car if it does then I know the newer motor should work.
Timbuk
  • Telford
  • owned a Datsun 120y once!
Re: Sunroof Motors
« Reply #9 on: 20 April 2007, 10:07:18 »
If snappa's is differet the car i am breaking is a 95 with ir, should all be the same :y
nixoro
  • Hitchin, Herts
Re: Sunroof Motors
« Reply #10 on: 20 April 2007, 10:10:38 »
Cheers Timbuk, I shall keep you in mind if i find the motor is not compatible with my car.
The Barge Captain
Re: Sunroof Motors
« Reply #11 on: 20 April 2007, 15:10:52 »
I've got an idea that the only difference is that the IR red dome is on it's own plug,
but then again.....
nixoro
  • Hitchin, Herts
Re: Sunroof Motors
« Reply #12 on: 20 April 2007, 15:51:10 »
but then again.....
So you reckon the early and later motors are the same and the connections are the same then, just want to swap for the newer one where you pull the dial off from the pin and not pull the dial and pin out of motor if that makes sense.
