Author Topic: can automatic Omega`s tow caravan`s???????  (Read 6026 times)
wheelchairkid
  • Northampton
« on: 19 April 2007, 16:32:16 »
Hi to all
              I have got a 1995 Vauxhall Omega CDX auto 2.5, it has done 73,400 miles from new. I want to get a caravan and get away for a while, has any of you ever towed a caravan with a automatic Omega? :-/ If yes what size and weight is your caravan and how did it tow?
                                             Yours
                                              Jason :y
It was not me, I did not touch it, I was not there!
Re: can automatic Omega`s tow caravan`s???????
« Reply #1 on: 19 April 2007, 16:36:38 »
Hi to all
                                             Yours
                                              Jason :y
I am sure many on here have towed caravans, if only to clog up the roads and upset me ;)
The Omega is a very good towcar apparently, and the autobox has an oil cooler, so thats not a problem.  If you are doing lots of towing, renew the autobox fluid more regular...
« Reply #2 on: 19 April 2007, 17:22:12 »
Many members here have automatic Omega's and tow fairly big Caravans.
As mentioned the box has a oil cooler so towing is now a problem, the low down grunt of the V6 helps too  :)
I belive 1 member here used to tow in a 3.0 MV6 and with a carvan in tow, showed a Citroeon Piacsso a thing or two at the lights   :o  ;)
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #3 on: 19 April 2007, 17:36:04 »
[/quote]
[/quote]
However!  If you have towed before you can legally tow a van, when fully laden does NOT exceed the mass weight of the Omega fully laden.. i.e. 1:1 ratio... I suggest only for experienced towers!!!!!  Realistically! the ideal ratio is 85% of the weight of the Omega, get a decent stabiliser bar or Alko combined hitch...  My 3.0l auto has bags of torque at around 3k revs when towing my 1000kg van..  It'll pull half as much again, NO PROBLEM....  :y
Just keep out of the way of bikers and travel at night, it's far easier.....   ::) ::) ::) ::) ::)
Also as TB says, the Omega has a cooler as standard...  Have you got an auto too??
DC
« Last Edit: 19 April 2007, 17:40:05 by dave_c »
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #4 on: 19 April 2007, 17:41:50 »
Hi to all
                                             Yours
                                              Jason :y
Sorry didn't read it properly, never listened at school either!
DC
wheelchairkid
  • Northampton
« Reply #5 on: 19 April 2007, 17:43:15 »
Hi yes my Omega is auto, I used to tow a twin axle caravan with my old shogun, but I had to get rid of that because getting in and out of it  from my wheelchair got to hard.
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #6 on: 19 April 2007, 17:50:30 »
Look for a van about 1300 kg , no sweat for your Meega!
DC
Martin_1962
« Reply #7 on: 19 April 2007, 19:11:24 »
It was a dual carriageway and a Renault Scenic
Had a few with the 2.6 as well!
Martin_1962
« Reply #8 on: 19 April 2007, 19:17:42 »
I have a Bailey Discovery 400 and I have towed it with 3 cars, the 2.0 was a little under powered but still managed OK. The rolled car was very good, with the extra torque and stiffer suspension. The 2.6 has done around 700 miles so far towing with no problems - including mid Wales mountains and M5/A30 to Cornwall.
On the A39 out of Wadebridge going East I was able to maintain a totally unsuitable speed up the hill - but the w****r in the Fixed or repaired daily Escrap struggled past at 80 and then slowed right down and held me up >:( I did not want to do 80, but if I had to the car would have done it.)
Basically the auto Omega is a very accomplished tow car, only weakness is softish suspension, but then this is kinder to tha A frame
bigall
  • merseyside
« Reply #9 on: 19 April 2007, 19:56:30 »
yes they can,
 I tow a 1.2 kg (empty) van with my omega - keeps to legal max speed very well. I am wary of a length of pipe in the radiator to act as  gearbox fluid cooler ( I know Vall say its all thats required) so have always had an air cooled oil rad fitted.
pre updatable  autoboxes tend to hunt for gears and can become a bit of pain. You may find it smoother to stick the lever into 3 if this happens
I drive a moneypit Omega - at least its comfortable!!!!!  200k approaching rapidly!!!!!!!!! "") (must change oil soon)
« Reply #10 on: 19 April 2007, 20:05:39 »
yes they can,
Remember, the g/b oil is cooled by the coolant in the cold side of rad, not by the airflow over rad.  This helps keep the oil cool...
Pete Elite
  • Uxbridge, Middlesex
« Reply #11 on: 19 April 2007, 20:10:51 »
yes they can,
  Hi Bigall,
              I think my Mum's Budgie would be able to pull that ok ;D ;D ;D.
« Reply #12 on: 19 April 2007, 21:38:20 »
A properly loaded 'van shouldn't need a stabiliser of any kind. Although I haven't yet towed anything more than a trailer to the tip with my Omega - yet! - I've towed a large-ish 'van behind my Senator for miles & miles, both here & in France, and have never had some much as a twitch from the caravan.
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #13 on: 20 April 2007, 17:53:31 »
I would like to agree fully about the loading issue...  However, I've had a few mates who've had blow outs... Stabilisers save lives!  It's that simple!!  One of them now has 2 x 200Q's and an Alko...  I had used to tow without one too, wouldn't consider without now though..  Call it insurance!! :y
DC
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #14 on: 20 April 2007, 18:03:16 »
Another handy thing about the Omega autobox is that it is adaptive which when towing reduces the amount of uneeded gear changes, I don't know from what year this was fitted I'm sure that someone will be able to tell you shortly
