how do you change sidelight bulbs
Started by tonycooper, 21 April 2007, 10:07:27
Quote:-[ Oh well i'll get my coat
It will go off the second you disconnect the battery if you do not use the correct procedure (disconnect battery within 15s of switch off ignition)...
Not on my car it doesn't ::)
Due to not having a (proper) alarm....
Correct, but there again you knew that :P
Does'nt on mine either as someone has disconnected the sounder :(
tonycooper
wish i looked at the replys before i started took me ages to work out how to turn off the alarm all done now tho
Quotewish i looked at the replys before i started took me ages to work out how to turn off the alarm all done now tho
You could of course have read the owner's manual before you started!  ;)  ;)  ;D
tonycooper
i am a man when do we ever do anything the easy way
hotel21
Quotei am a man when do we ever do anything the easy way
Did you go to the same school as me at a different time??   ;D  ;D
I just use a set of jump leads so the battery can still be connected when its on the floor ::)
hotel21
QuoteI just use a set of jump leads so the battery can still be connected when its on the floor ::)
Excellent....  Never tought of that..   :y
B
Markjay
I found it easier to remove the headlamp than the battery.... both are 5 minute jobs actually, so not sure if there is a clear advantage to one over the other, but here's what I did:
http://www.cavweb-forums.co.uk/showthread.php?t=86215
(sadly I never copied-over this guide to OOF...)
Alas, no more Omegas....
hotel21
Quote......(sadly I never copied-over this guide to OOF...)
and control insert / shift insert means???
:y   ;D   ;D   ;D
go on, you know you need to......   :y
