Author Topic: alternator noise  (Read 2607 times)
paul.c
  • east calder scotland
  • hands off shes mine
alternator noise
« on: 22 April 2007, 11:19:41 »
hi guys. my alternator bearings are making a racket so i was wondering if anybody has changed them and what was involved in the job. also would i need special tools to do this,. any advice :(
Re: alternator noise
« Reply #1 on: 22 April 2007, 11:25:10 »
« Reply #2 on: 22 April 2007, 11:26:38 »
Sorry I jumped the gun a bit there as there is no mention of bearings :-[
« Reply #3 on: 22 April 2007, 12:11:23 »
Easy enough to do.....idealy you need a puller and either an impact screwdriver or a good rechargeable drill (they need shocking out!) to get the 4 bearing plate screws out...you also need a star drive to hold the rotor shaft whilst you undo the large nut that holds the pulley on...
Other than that there are only two bearings.....
 1 off 6203 2RS
 1 off 'cant remember but same bore and thickness as the oterh but larger diameter'
paul.c
« Reply #4 on: 22 April 2007, 23:17:01 »
do you know where i can buy them ?
Matchless
  • Nottingham
    • A white van
« Reply #5 on: 22 April 2007, 23:28:35 »
1x 6303-2RS
1x 6203-2RS
Try Simply Bearings on the web or their ebay shop.
Markjay
  • London
« Reply #6 on: 22 April 2007, 23:41:31 »
1x 6303-2RS
1x 6203-2RS
Yep...
Front:
NSK NSK6303R / Bosch 1120905068 / Vx 90512010
Inner Diameter 17
Outer Diameter 47
Width 14
Rear:
NSK BRG62032RS / BOSCH 1120905083 / Vx 90540406
Inner Diameter 17
Outer Diameter 40
Width 12
Alas, no more Omegas....
