Author Topic: help with fault code 98  (Read 1438 times)
paintshoptec
  • cheadle, stoke - on -trent
    • 2002 cd v6 saloon
« on: 24 April 2007, 06:40:49 »
when towing my caravan the managment light comes on ,then goes of when slowing down ,but there is no probs when not towing, the only fault showing is 98 can anybody  help
« Last Edit: 24 April 2007, 06:42:34 by paintshoptec »
Admin
Re: help with fault code 98
« Reply #1 on: 24 April 2007, 07:20:01 »
Hi and welcome to the site. :)
Code 98? That is an oxygen sensor fault code, but I suspect it is an indication of a fault elsewhere.
If it only comes on when the car is under load towing a caravan then I suspect a potential fuelling issue.
Does the car behave completely normally when not towing?
Which model and year do you drive (I guess it is a V6 judging by the fault code).
The Administrator.
rpont
  • Tadcaster
« Reply #2 on: 24 April 2007, 09:57:44 »
When was the fuel filter last changed?
« Reply #3 on: 24 April 2007, 09:58:41 »
......and when was the fuel filter last changed......does it red lien in second without any problems....or does it cut out before then
paintshoptec
    • 2002 cd v6 saloon
« Reply #4 on: 24 April 2007, 15:07:12 »
its a 1998 model ,the car drives fine with no probs when not towing, the fuel filter was change 6 month ago and done aprox 40000 miles
« Last Edit: 24 April 2007, 15:10:02 by paintshoptec »
