Author Topic: ABS/TC doesn't work  (Read 5005 times)
Arrolman
  • Renfrew,Scotland
ABS/TC doesn't work
« on: 21 April 2007, 19:34:19 »
Hi all,
My ABS and TC have stopped working, no idea how when or why, anyone got any suggestions??
Cheers,
Iain
Looking to win the lottery..........
Re: ABS/TC doesn't work
« Reply #1 on: 21 April 2007, 20:22:36 »
Hi all,
Cheers,
Iain
Don't tell me, its a 1998 or later car....
Arrolman
  • Renfrew,Scotland
« Reply #2 on: 21 April 2007, 21:01:22 »
Hi,
No,Its a P reg, 96 car
« Reply #3 on: 21 April 2007, 21:09:46 »
Hi,
Ah, thats good news ;)
Are the lights on on the dash?
Arrolman
  • Renfrew,Scotland
« Reply #4 on: 21 April 2007, 21:12:59 »
ABS lights is there, won't light up under any kind of braking, TC lights will only come on when I manually pres the button, no difference though, no TC, wheelspin is easy round any corner
Cheers,
Iain
« Reply #5 on: 21 April 2007, 21:15:26 »
Cheers,
Iain
ABS light should only light up if there is a fault (and during system startup when ignition turns on).  Does ABS light come on with ignition for a second or 2?
Arrolman
  • Renfrew,Scotland
« Reply #6 on: 21 April 2007, 21:18:41 »
Hi,
ABS and TC lights light up on startup then extinguish, they came on about a month ago for about 10 mins as I drove home, switched off and restarted engine and they went off, not been like that again
Cheers,
Iain
« Reply #7 on: 21 April 2007, 21:21:03 »
Hi,
Cheers,
Iain
So, as far as the system is concerned, everything is OK, but your TC isn't working? Is the ABS working (gently test on a bit of gravel)?
Arrolman
  • Renfrew,Scotland
« Reply #8 on: 21 April 2007, 21:22:23 »
Hi,
No, not working at all, skidded a couple of times and theres no feedback at all
Cheers,
Iain
« Reply #9 on: 21 April 2007, 21:27:35 »
Hi,
Cheers,
Iain
OK, I need to think about this one.
If it was one sensor failing/wrongly adjusted etc, I would expect it to light up the dash lights.  If it was one of the pumps in the ABS unit, that shouldn't stop TC working.
Arrolman
  • Renfrew,Scotland
« Reply #10 on: 21 April 2007, 21:29:07 »
Hi,
Might be a stab in the dark but my brake pads are due too get changed, could that be the cause?
Cheers,
Iain
« Reply #11 on: 21 April 2007, 21:34:42 »
Hi,
Cheers,
Iain
Unlikely...
Arrolman
  • Renfrew,Scotland
« Reply #12 on: 24 April 2007, 16:35:56 »
Hi,
Anyone shed any light on this? Beginning to seriouslly annoy me
Cheers,
Iain
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #13 on: 24 April 2007, 19:20:34 »
Cheers,
Iain
And what about the ABS when braking hard??  What I mean is, can you feel the pedal pulsating?
At the monent, I'm thinking grotty sensors at the rear, not enough to show up a fault, but, enough to prevent the system interveinig..  Maybe worth a look, at the rotors either side of the diff under the back!!!  MUD...
DC
« Last Edit: 24 April 2007, 19:21:57 by dave_c »
« Reply #14 on: 24 April 2007, 19:24:17 »
I assume F19 is ok....
