Smokin' Omega... HELP!!
Started by hugster62, 24 April 2007, 21:22:54
Gaffers
does it happen under heavy load? (heavy acceleration/ going uphill)
How old is the oil?
Is there signs of oil leaking from the rocker cover?
I had a similar baffling problem with my old 4 pot veccy (same engine)  I changed the oil and filter an dhey presto!!!
hugster62
Ok
I have taken the Ecotec cover off and here's what i found underneath
http://www.studio62.co.uk/plugs.html
Is that what i should see?
Thanks for all your help guys, really appreciate it
Gra
Pull the plug leads, is there any oil in there?
hugster62
Hi the oil is quite new but it does only happen under acceleration (in the car were myself, the wife and three kids) I do have an oil leak but under the car, i've just posted a couple of images that may be of help in explaining what the problem is.
Gra
cdx25
QuoteOk
Gra
Whats underneath the plug cap?  When my cam cover gasket went the plugs became full of oil...
cdx25
QuotePull the plug leads, is there any oil in there?
TB you must have beat me by seconds there ;-)
Keep up  :P
hugster62
ive checked the plugs, they aren't sitting in oil that's for sure but there is a very faint trace of oil on the rubber plugs as they come out. Inside the plugs they are really quite clean, no oil but they progressively "sticky" towards the back of the engine... it could be oil, it has a slight yellowy colour on the inside of the plug sockets.
Gra
Pop a bit of kitchen roll in the rear plug well, and see if the corner comes out oily.  Until you've seen it before, its difficult to visualise what it should be like.  Any wet oil on the kitchen roll will mean the gaskets have failed...
hugster62
hugster62
put some kitchen roll in, i wouldn't say it was oily, definitely not wet but did come out "dry dirty"
Martin_1962
Well that is one of the main smoke causes the oil drips onto the exhaust creating smoke.
Check the manifold & downpipes for signs of burnt oil.
Seals would be on startup.
Rings would be whenever under power.
QuoteHere's inside the plug socket if thats any good
http://www.studio62.co.uk/inside.html
Can you get a better picture, showing all the way down...
hugster62
Hiya Martin
There is an oil leak that's for sure but the exhaust manifold and downpipe look actually really clean, just rusty. This has happened three times, the forst two were under acceleration, big white plumes of smoke, the third time it seems to be pumping out smoke from startup but only if i rev the engine, so if i just turn it over and start it, nothing, no smoke, if i rev it then it starts to smoke.
Thing is, oil smoke is blueish in colour...
