Do I have a LSD?
Started by Joneyentee, 26 April 2007, 23:54:09
Joneyentee
#15
QuoteHere's a wild guess:
If you jack-up one rear wheel, then switch of TC, put in gear and rev the engine - if no LSD, the wheel on the jack should turn freely while the other is firmly on the ground.  :y
On the other hand, if you have LSD, then wheel on the ground will also start rotating (albeit at a much lower speed then the jacked-up wheel) and er... the car will fall of the Jack and fly forward... or something... so maybe not such a good idea...  :-[
So perhaps not a very practical test but as a matter of principal I think this would prove LSD / no-LSD?  :o
LMAO!
I think I'll stick to trying the steering lock and dumping the clutch test first. Maybe I'll try your way if I'm still not sure......  ;)
Quotebut if you dont have an LSD you can always do this :o
I'm sure that pic means something to some people, but to me it's just some bits of metal....  :-[
QuoteA safe way to do the above test might be to park up with one wheel on an area of low traction, a grass verge by the side of the road, for example, while the other wheel is on tarmac, switch off the TC and pull away swiftly.
And if I leave a wheelspin mark in the grass then I don't have a LSD right?
Reading of signatures prohibited...
palmer3914
#16
I GOT ANOTHER WAY!!!!
watch this video!!!!!!!!!!!!! of my omega before i did anything to it ..... just wheels.....
I WAS SEEING IF I HAD A LSD...errrrrr sort of.....
Do what i do and see if you can see 2 black marks not 1 :y :-? :P
http://smg.photobucket.com/albums/v490/palmer3914/?action=view&current=MOV00264.flv
now thats a DIFF!!!!!!!!!!
Joneyentee
I guess if I don't have a LSD then I would only need to replace one tyre.... ;)
palmer3914
YOU GOT IT IN 1 !!!!!!!!!!!!!!!!  ;)
LMAO :'(
