Author Topic: Omega 2.5v6 Tappy Engine  (Read 2546 times)
wastedperfection
  • Stoke on Trent
« on: 01 May 2007, 19:36:28 »
Hi,
After giving my v6 a bit of a thrashing the engine is rattly , like a tappet noise.
Any way to cure it other than replacing the tappets?
Matt
Re: Omega 2.5v6 Tappy Engine
« Reply #1 on: 01 May 2007, 19:38:56 »
More regular oil changes. Hopefully you are not changing at the recommended 10k ;)
Dean
  • Weston Super Mare - UK
« Reply #2 on: 01 May 2007, 19:39:42 »
My own 2.5 does his when cold but after a minute or so goes quiet.... just changed the oil and it still does it.
I have read somewhere this is reletively normal.
However is your is doing it when warm it may be signs of problem.
Someone will pip up in a minute with there opinion and hopefully a solution for you.
Free Traffic law advice  - Just PM or see the sticky thread in General Chat ! http://www.omegaowners.com/forum/YaBB.pl?num=1177278724 - no liability accepted
« Reply #3 on: 01 May 2007, 19:40:32 »
If only does when cold, check the exhaust manifold and its gasket...
wastedperfection
  • Stoke on Trent
« Reply #4 on: 01 May 2007, 19:40:36 »
Well only just bought it , so ill try an oil change. ANy recommendation for the oil? , semi synthetic or full? , thicker oil to quiten it or not?
Matt
« Reply #5 on: 01 May 2007, 19:41:25 »
Matt
Vauxhall's own semi synth, but quite expensive if you don't have access to Trade Club
wastedperfection
  • Stoke on Trent
« Reply #6 on: 01 May 2007, 19:42:16 »
All i get when from cold is a little rattle then quiet (oil pump probably needs replacing) , its quite as a mouse when warm its only when ive given it a good thrashing down the road that it rattles
Matt
cdx25
  • Plymouth, UK
« Reply #7 on: 01 May 2007, 20:52:38 »
Matt
Wouldnt necessarily blame the oil pump here - on most engines this is often the best lubricated bit....
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #8 on: 01 May 2007, 21:40:55 »
Matt
That's all the bloody pot holes around here!!!
Try an oil and filter change, Ask for trade discount at Greenhous's, blag it son, blag it!!  Shelton Auto Spares (Above Signal Radio)also occasionally sell VX semi / synth oil, less than a tenner............
Get that cam belt changed too, if you've got no service history or receipts.
Dave C
