Author Topic: intermittent clicking of 2 pink relays  (Read 1794 times)
lawbet7eb
« on: 02 May 2007, 10:46:13 »
hi all
car: opel omega 2002 with 2.2 petrol engine
problem : wont start
diagnostics code says : 340 ( camshaft sensor)<=== changed
still not working, but i hear intermittent clicking of 2 pink relays which i believe for fuel system...
any ideas will be appraiciated..
Markjay
  • London
Re: intermittent clicking of 2 pink relays
« Reply #1 on: 02 May 2007, 11:43:40 »
Welcome to the forum...
Are the relays in the engine bay? If so have a look at:
http://www.omegaowners.com/forum/YaBB.pl?num=1176582166
http://www.omegaowners.com/forum/YaBB.pl?num=1176560725
http://www.omegaowners.com/forum/YaBB.pl?num=1176542233
http://www.omegaowners.com/forum/YaBB.pl?num=1176150697
http://www.omegaowners.com/forum/YaBB.pl?num=1161602726
These diagrams are NOT specifically for the 2.2, but should be similar enough, so see if you can identify your clicking relays and point out which ones are they?
« Last Edit: 02 May 2007, 11:45:04 by markjay »
Alas, no more Omegas....
nixoro
  • Hitchin, Herts
« Reply #2 on: 02 May 2007, 15:10:26 »
hi all
I'd be tempted to check fuse 18 for the fuel pump. (Under the steering wheel i think its fuse 18)
When you turn the key is it just the relays clicking or do you hear a noticable noise as I hear a noise when the fuel pump kicks in.
Just a suggestion and I maybe way off the mark but its worth checking :y
« Last Edit: 02 May 2007, 15:11:19 by nixoro »
lawbet7eb
« Reply #3 on: 02 May 2007, 18:56:07 »
thank you all so much.
i went to take a pic for the relays box and record the sound. but the car just cicked and started  :question :question :question :-?
strange............. would it stop again shortly.... i hope not but if it does stop... i'll set it on fire..
thanks all for everything.
Page created in 0.009 seconds with 20 queries.
