Nasty noise
Started by JasonH, 28 April 2007, 22:31:47
Matchless
QuoteThanks for that another area to check.
If it is the air con compressor it's good and bad, safe to drive, well safeish, but bad 'cause I suspect it will be expensive to replace....
If it is the a/c compressor pulley bearings then dont run it like that, get an aux belt for a 2.0 with a/c and fit it so it by-passes the a/c pulley.
A/C noise is usually the compressor clutch or pulley bearings, the whole pulley and clutch assy can be pulled off the shaft and the bearings replaced without disturbing the refrigerant circuit but it needs a special puller.
ffcgary1
 ;)Someone on here will have ac compressor lying about in their garage needing a home me thinks. ;)
Jaguar XJ6
JasonH
Car transported home on the back of a lorry. Thanks to the nice people at the RAC.
Slipped the aux belt off - noise gone.
Span the tensioner and water pump by hand......it's the water pump. Spins  OK but feels rough, spin it fast and you can hear the start of the nasty noise.
Phew, not too bad  :y
QuoteCar transported home on the back of a lorry. Thanks to the nice people at the RAC.
Nice easy change as well. Is cambelt nearly due?
Markie
and cheap too - with change out of £25 on trade  :y
JasonH
Got the pump now £21.42 + VAT
Going to just do the pump, cambelt has another 15k in it.... I know I know but I need to fix the car quickly as well.
Chopsdad
Not fair. >:(
I was going for the water pump as it sounds same as mine when it went 2m ago, and I too came back behind a tow truck...but by the time I got to the end of the thread you'd fixed it. :-/
Glad it was so simple and cheap to fix though  :) :y
The Barge Captain
Glad you got it sorted mate.
JasonH
Thanks everyone - let's hope it's dry on Saturday so I can fix it.
Markjay
QuoteThanks everyone - let's hope it's dry on Saturday so I can fix it.
Good luck! let us know how it went...
Alas, no more Omegas....
