Author Topic: New Remote key  (Read 2383 times)
mv6copcar
  • Essex, Halstead
New Remote key
« on: 03 May 2007, 21:54:59 »
Hi people,
if i was to buy a new remote key (IR) , got the metal part cut to match my curant one, how would i go about programing the Ir side?
also is there a transponder chip in my key?
regards
Re: New Remote key
« Reply #1 on: 03 May 2007, 22:02:13 »
Specialist equipment needed, such as Tech1...
mv6copcar
  • Essex, Halstead
Re: New Remote key
« Reply #2 on: 03 May 2007, 22:06:58 »
thanks,dont seem to be having much luck here.tried everything to do with the remote key,stripped it,cleaned it,new batt but still only unlocks the dam car,not locking or opening the boot.  stick with the key and boot button in the car for all the hassle its worth!+ £££££ on top!
thanks
Re: New Remote key
« Reply #3 on: 03 May 2007, 22:09:57 »
Hang on a mo, you say yours is IR, yet your profile says 2000 model (RF). If RF, Tech2, or most autolocksmiths have the kit.  You will probably need your carpass...
mv6copcar
  • Essex, Halstead
Re: New Remote key
« Reply #4 on: 03 May 2007, 22:13:13 »
sorry mate-lost me there. don't know what the difference is  :o
its a 2000 w reg facelift model. the garage i spoke to say that if i can unlock the car with the remote key,i should be able to lock also!
well out of my depth lol
cheers
also what is a car pass?saw someone talking about that on another thread.
« Last Edit: 03 May 2007, 22:14:17 by mv6copcar »
Re: New Remote key
« Reply #5 on: 04 May 2007, 09:35:15 »
OK, you have a radio frequency (RF) remote, rather than the earlier infrared (IR) type.  Tech2 (or similar) required to program new remote to the car, and this will require the Immobiliser PIN code which is a 4 digit code unique to your car. These code (along with other codes such as radio) is on the 'carpass' which would have been supplied to original owner, but probably lost...
Tony H
  • liverpool
  • Black Elites are luurvley
Re: New Remote key
« Reply #6 on: 04 May 2007, 19:38:20 »
You can obtain a new car pass from the main stealers You will have to take proof of ownership of the vehical, oh and by the way expect to be bent over the counter with the cost of a bit of thin card :o it can vary from £16 to over £30 best bet is to ring around for the best price :y
Re: New Remote key
« Reply #7 on: 04 May 2007, 21:45:36 »
Or £45 at my favourite scumbag dealer....
wakeyomega
  • Wakefield
Re: New Remote key
« Reply #8 on: 04 May 2007, 23:45:53 »
I was intrigued as to why I'd never needed a new battery in my key after having it for nearly 7 years (facelift elite),  so I opened it up the other week, to look at what type of battery it took and I couldn't see a battery, just  little 'dongle'. Is this right?  :-/ if so, what is the little dongle bit?
Ta Pat
Remember, if you ever need a helping hand, you'll find one at the end of your arm
Re: New Remote key
« Reply #9 on: 05 May 2007, 19:45:17 »
The immobiliser transponder doesn't need power, but the rf remote locking does....
Page created in 0.008 seconds with 16 queries.
