Author Topic: Interior door trigger thingie  (Read 3824 times)
theolodian
  • I need a new avatar.
« on: 07 May 2007, 10:33:48 »
What breaks on these?  Mine bends down a lot when I open the door, sometimes catches the trim and pops it off.  Worried that it will fail soon.  Can take door apart, but would like to know what I might need to get if anyone has had this before.  :question
ians
  • Reading
Re: Interior door trigger thingie
« Reply #1 on: 08 May 2007, 11:17:52 »
.... I'm not sure which thingie you're referring to theolodian.  can you clarify?
« Reply #2 on: 08 May 2007, 11:32:07 »
Me to.....any chance of a pic?
STMO123
« Reply #3 on: 08 May 2007, 11:39:10 »
I guess he means the interior door handle opening gizmo whatsit :o
theolodian
« Reply #4 on: 08 May 2007, 11:40:15 »
Ummm.  The thingie you pull to open the door, from the inside.  Cable runs from it to the latch in the door jamb.
STMO123
« Reply #5 on: 08 May 2007, 11:47:03 »
The top or bottom pivot may have broken/come loose, or, the plastic housing may have broken. You should be able to tell just by removing the cover.
theolodian
« Reply #6 on: 08 May 2007, 11:55:48 »
Yeah, it feels like a top pivot isn't doing it's job.  I'll take a closer look in a bit.
theolodian
« Reply #7 on: 08 May 2007, 13:04:30 »
If there is supposed to be a round plastic pin sticking up from the tigger into the top of the bracket then that has broken off.
STMO123
« Reply #8 on: 08 May 2007, 13:25:30 »
Thats your problem then mate. Tunnie put some great pics of all the gubbins on here somewhere, although his was facelift.
ians
  • Reading
« Reply #9 on: 08 May 2007, 13:27:13 »
Is there one on the lever on the other side?  If so, I guess you are right.
I had a similar problem with the outside handle - the hinge pin came out at one side such the the handle didn't pull square and the door didn't release.
Hopefully if the one on the passenger side is ok you should be able to figure out what has broken or come off.
STMO123
« Reply #10 on: 08 May 2007, 13:32:00 »
Just been out and popped mine off Theo ( I really am too kind :D). Ita a metal pin and its looks possible that it could slip down and may need just pushing back up from the bottom.
theolodian
« Reply #11 on: 08 May 2007, 13:36:01 »
Cheers, I'll give that try.  :y
ians
  • Reading
« Reply #12 on: 08 May 2007, 13:40:22 »
If that's the case its a similar construction to the outside handle I mentioned, so hopefully the pin has just slipped down abd can be pushed back.   (Now you just need multijointed fingers to reach it ;))
STMO123
« Reply #13 on: 08 May 2007, 13:50:38 »
Or a flat bladed screwdriver ;)
ians
  • Reading
« Reply #14 on: 08 May 2007, 15:06:51 »
Oh come on - that's cheating ;D ;D
