Author Topic: Rocker gasket leak  (Read 2382 times)
john1dart
  • Cleckheaton, West Yorks
Rocker gasket leak
« on: 09 May 2007, 14:23:02 »
Firstly Hello to all as i'm new to the site.
After finding all the help i need on here I'll now be doing the above work myself as i'm a skilled engineer.
Are there an specialist tools i will need to replace rockers gaskets and clean crankshaft breather system?
should I clean the breather whist the top half of the engine is stripped down?
how long will this take start to finished?
any help will be greatly recieved.
Kind regards
I forgot to mention the car. its a 1996 2.5 V6 CD
« Last Edit: 09 May 2007, 14:26:35 by john1dart »
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Rocker gasket leak
« Reply #1 on: 09 May 2007, 14:47:19 »
If you look in the Maintence section you will find Beather cleaning, also Mark has done a section on Cam Cover Gaskets :y
http://www.omegaowners.com/forum/YaBB.pl?num=1152564281
ians
  • Reading
« Reply #2 on: 09 May 2007, 15:31:03 »
Welcome John!
Apart from a selection of torx bits,  a big spanner (adjustable) is useful to disconnect the EGR pipe, and a torque wrench that goes down to 8Nm for the camcover bolts.
Loads of carb cleaner for the breather cleaning.
Oh and I forgot the double jointed knees and the extra hand ;D ;D
Cheers,
Ian
cdx25
  • Plymouth, UK
« Reply #3 on: 09 May 2007, 18:05:19 »
Its in the maintenance guide but just to emphasise...
And the genuine Vx gaskets !
Jon
amba
  • Medway towns
    • German V6
« Reply #4 on: 09 May 2007, 18:34:19 »
Toally agree..only use genuine Vauxhall gaskets/"o" rings and Black sealant..that way they should stay oil tight....I speak from several bad experiences with after market parts,,,good luck
« Reply #5 on: 09 May 2007, 19:17:25 »
Genuine gaskets, as said!
Markjay
  • London
« Reply #6 on: 10 May 2007, 17:50:53 »
Yep, genuine Vx everything....
Alas, no more Omegas....
