Author Topic: Damp boot  (Read 2230 times)
NML
Damp boot
« on: 19 May 2007, 17:55:07 »
I've jst noticed that the boot on mt omega is damp as if its letting a bit of water in somewhere. Its more towards the back of the boot.
Anyone got any idea where it could be coming from?
nixoro
  • Hitchin, Herts
Re: Damp boot
« Reply #1 on: 19 May 2007, 18:02:30 »
Inside the boot to the right you have the first aid compartment, at the back of this there is a pipe which runs with the shape of the wheel arch into the floor my dads car was getting a wet floor and found the pipe was not going through the floor its to do with where the rain water goes.
Just something worth checking
HTH and makes sense
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: Damp boot
« Reply #2 on: 19 May 2007, 19:07:08 »
or it will be runing down the channels either side of the boot, or like a previous vectra I owned, coming up from underneath ( lift the boot carpet and check everything there)
« Last Edit: 19 May 2007, 19:07:50 by Markiec »
Omegatoy
  • UK
Re: Damp boot
« Reply #3 on: 19 May 2007, 20:06:26 »
On every one i have been asked to sort its always been the rearlight seals letting the water in!!!
remove lights and smear seals with clear silcon sealant or replace seals!! ;D
NML
Re: Damp boot
« Reply #4 on: 19 May 2007, 20:22:49 »
Cheers for that people :y. I'll have a look tomorrow
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
Re: Damp boot
« Reply #5 on: 19 May 2007, 20:24:33 »
I'd say it was WATER getting in - but I'm not very helpful  ;D
Danny
  • Wigan, Greater Manchester
Re: Damp boot
« Reply #6 on: 19 May 2007, 20:33:08 »
or to be less helpful..
could be caused by a wet sock?
« Last Edit: 19 May 2007, 20:33:25 by D4NNY »
Chopsdad
  • Keep it clean!
Re: Damp boot
« Reply #7 on: 19 May 2007, 20:35:30 »
Thanks Danny - mine was a bit damp too.  I've just checked it and it was completely empty apart from 1 damp sock right in the middle, I never thought it could be that.  Go figure  ::)
mv6copcar
  • Essex, Halstead
Re: Damp boot
« Reply #8 on: 19 May 2007, 22:10:28 »
do you have a sunroof? if so there are two pipes running from the sunroof, along the roof skin and exiting behind the rear wheel arch, as markie said about pipes, we could be talking about the same thing!
mine blocked on my 2.2saloon and caused a wet boot mat.
HTH
carl
gizza
  • baildon essex
Re: Damp boot
« Reply #9 on: 20 May 2007, 00:02:17 »
try checking the drain hole where the spare wheel goes may be blocked
