Author Topic: need help quick  (Read 3474 times)
nemesis_v6
  • tiverton devon
need help quick
« on: 20 May 2007, 13:04:39 »
just jump started a car and know my battery light stays on when i turn off the car along with the range screen brake light check screen even when the keys are removed pls help
Paul M
  • Edinburgh
Re: need help quick
« Reply #1 on: 20 May 2007, 13:30:14 »
Sounds like one of the relays is staying closed when it should open to disconnect power. Are you sure you've removed anything that can supply power to the car? What I mean is, did you use anything other than jump leads connected to the battery? If you apply power through the lighter socket it can do this.
nemesis_v6
  • tiverton devon
Re: need help quick
« Reply #2 on: 20 May 2007, 13:49:44 »
no just jump leads so if i tap the relay it might sort its self out but leve the hammer in the tool box for this thanks for some info on this
nemesis_v6
  • tiverton devon
Re: need help quick
« Reply #3 on: 20 May 2007, 13:50:32 »
ill just try the relays back in a mo
nemesis_v6
  • tiverton devon
Re: need help quick
« Reply #4 on: 20 May 2007, 13:55:46 »
gave relays a light tap but to no avill
Re: need help quick
« Reply #5 on: 20 May 2007, 14:49:24 »
knacker ign switch? Perhaps this is why battery went flat?
nemesis_v6
  • tiverton devon
Re: need help quick
« Reply #6 on: 20 May 2007, 17:57:40 »
no may meega wasnt flat i was jumping someone alse
paul.c
  • east calder scotland
  • hands off shes mine
Re: need help quick
« Reply #7 on: 20 May 2007, 18:20:47 »
same thing happend to me but on a granada.it turned out to be a fuse
nemesis_v6
  • tiverton devon
Re: need help quick
« Reply #8 on: 20 May 2007, 18:44:20 »
check most fuses under streeing wheel
Admin
Re: need help quick
« Reply #9 on: 20 May 2007, 19:21:15 »
This is a weird one.  :-/
Only thing I can think is the load drop on the system when the other car was jump started has caused a relay to stick open?
I await Marks suggestion....
The Administrator.
