Author Topic: crank oil seal  (Read 2356 times)
paul.c
  • east calder scotland
  • hands off shes mine
crank oil seal
« on: 20 May 2007, 19:26:03 »
front crankshaft oil seal is leaking on my friends car im going to have a bash. has anybody done this. whats with all this angle tightning crap what ever happend to good old F. T. also any suggestions on how to stop the engine turning when giving the big nut some muscle..?
Martin_1962
Re: crank oil seal
« Reply #1 on: 20 May 2007, 19:36:34 »
auto or manual?
Matchless
  • Nottingham
    • A white van
Re: crank oil seal
« Reply #2 on: 20 May 2007, 19:37:25 »
This is on a V6 ?
I might be looking at a similar job myself, just havnt confirmed where the leak is yet.
Are you sure that it isnt leaking from the oil pressure sensor? A good clean with degreaser might help you track the path of the oil, trouble is that it gets blown everywhere so its difficult to work out where its coming from
It seems that leaks from the front seal are fairly rare, most likely it is leaking from alloy sump - block joint or from oil pump - block joint.
To reseal the sump joint requires the front subframe to be lowered and that means supporting the engine from above.
The oil pump joint requires the A/C to be degassed and compressor removed then remove the cambelt etc and the toothed crank pulley.
To remove the toothed crank pulley (your original question) you MUST bolt a length of steel angle etc to the pulley and use that to stop the pulley turning, if you try to do it by locking the crank or putting it in gear etc then you will shear the pulley drive pin.
paul.c
Re: crank oil seal
« Reply #3 on: 20 May 2007, 19:45:07 »
yes i ment to say that its a v6 and its definatly the crank seal
paul.c
Re: crank oil seal
« Reply #4 on: 20 May 2007, 19:49:29 »
and its a manual
Matchless
  • Nottingham
    • A white van
Re: crank oil seal
« Reply #5 on: 20 May 2007, 19:53:54 »
What makes you so sure? Have you removed the cambelt cover and seen oil around the sprocket or what? .... I have a similar oil leak but cant pinpoint it....and all the possible places involve a lot of work so would like to do the job once only.
paul.c
Re: crank oil seal
« Reply #6 on: 20 May 2007, 20:15:09 »
cleaned the whole area with gunk took off oil presure switch checked it under a microscope ( its a joke ) but on starting the engine and looking up directly at bottom of pulley ( behind it ) within 2 seconds a line of oil appeard from seal
