Author Topic: Oil Cooler !! IT STARTED !!  (Read 2253 times)
andycuk71
  • Reading
« on: 23 May 2007, 10:10:47 »
Hi
Latest installment!!!
Started car fine and is running better and no sign of leaks...
Have put in 5 litres of oil initally and came up with oil lack so put in another litre but dipstick is reading just over the min how many litres should it take????
Engine management light is staying on. Why?
Think it is idling to slow runs for about 4-5 mins then dies, but starts again fine how do you adjust idle speed?
Many Thanks
Andy
Danny
  • Wigan, Greater Manchester
Re: Oil Cooler !! IT STARTED !!
« Reply #1 on: 23 May 2007, 11:01:19 »
i was under the impression you should usually have 6 litres of oil in
MikeDundee
  • Costa Del Peckham
« Reply #2 on: 23 May 2007, 11:09:50 »
5.75 according to the vauxhall maintenance manual but thats with a filter change, so may be slightly less.
« Reply #3 on: 23 May 2007, 11:36:10 »
Its likely to be more with an oil cooler change as there will be no oil in the oil cooler pipes or oil cooler as well as the filter and sump.....
The project LPG car took 6 litres.....
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #4 on: 23 May 2007, 15:48:10 »
Congrats Andy....How does it sound ?
Reason i ask is i have just done one of these ( As Mark DTM is only to aware  ;D )
Due to some cooling issues i really havent been able to idle it for more than 2 minutes or so....to me the engine sounds very tappety....how does your sound?
Im hoping its just due to never getting the car to operating temperature... yet... :-/ if not then somethings still wrong  >:(
« Last Edit: 23 May 2007, 15:49:37 by Markiec »
Markie
« Reply #5 on: 23 May 2007, 15:48:51 »
...and whats it idling at rpm wise?
andycuk71
  • Reading
« Reply #6 on: 23 May 2007, 15:55:17 »
Engine sounds fine better than before... rpm idle is around 400rpm which I think is a little low anyone care to comment
« Reply #7 on: 23 May 2007, 17:53:35 »
About right with Climate off
andycuk71
  • Reading
« Reply #8 on: 23 May 2007, 18:05:00 »
Ok flashed the Diagnistic thingy and found the following fault codes.
19 = RPM Crankshaft sensor
59 = Inlet manifold valve
132 = Exhaust gas recirculation valve
Any thoughts anyone???
« Reply #9 on: 23 May 2007, 18:27:42 »
I've replied to this in your seperate thread :)
http://www.omegaowners.com/forum/YaBB.pl?num=1179939971
« Reply #10 on: 23 May 2007, 18:35:19 »
and so have I.
Markie
« Reply #11 on: 23 May 2007, 18:42:13 »
...and your revs are fine  :y
