Pages: [1] 2 3  All   Go Down
Author Topic: more ponies  (Read 7966 times)
azzbo
  • pontpool south wales
more ponies
« on: 14 May 2007, 20:47:14 »
 ;Dis there any way of getting more ponies from a 2.5td and can anyboby recomend a good supention set up but i also tow a caravan so it cant be to silly :y
Re: more ponies
« Reply #1 on: 14 May 2007, 20:57:36 »
Have a word with Omegatoy - he tows and has a chipped Omega.  Top bloke as well :y
I intend to chip my tractor as soon as I can keep the useless heap of junk cool  >:(
Omegatoy
  • UK
Re: more ponies
« Reply #2 on: 14 May 2007, 22:03:37 »
more ponies is easy matre, as to susapension i have Irmsher uprated lowered springs and poly bushes, along with airshocks for towing!! so it handles well on its own and is quite capable of towing the twin axle van as well!!!
palmer3914
  • ipswich / suffolk
Re: more ponies
« Reply #3 on: 15 May 2007, 09:11:40 »
sorry to jump in here omega toy....... where the hell did you get poly bush's from i cant find any anywhere :'(
and really need some what bushes arte polly'd and where you get them from?
please please please :D
now thats a DIFF!!!!!!!!!!
stevief
  • Aberdeen
Re: more ponies
« Reply #4 on: 15 May 2007, 13:53:55 »
Are the air shocks on self levelling or seperate valve? Also if there are self levelling did you have to adjust it in any way?
As you may have guessed I'm looking at uprated springs but keep hitting the not suitable for self levelling bit and as all the shocks are newish I'm still undecided.
Steve
Dave-C
  • Staffordshire
  • The Old Girl
Re: more ponies
« Reply #5 on: 15 May 2007, 19:50:57 »
See HIGHLIGHTED, indeed where??????????
azzbo
Re: more ponies
« Reply #6 on: 15 May 2007, 20:18:03 »
would it be a chip or a map :-?
i think i have standerd shox my car also seems to sit high at the rear is this common
 :o;D
miggy
Re: more ponies
« Reply #7 on: 15 May 2007, 20:20:31 »
Any info on where I can get a re map omegatoy, Been told it is best to have the car done on a rolling road.
 :o
Omegatoy
  • UK
Re: more ponies
« Reply #8 on: 15 May 2007, 20:23:36 »
Ok being as you asked nicely, actually got mine from australia as part of a group buy, however they are available in uk as the same bush fits the senator 24v and the the carltongsi and the 4x4 calibra!!!
that help?
Omegatoy
Omegatoy
  • UK
Re: more ponies
« Reply #9 on: 15 May 2007, 20:27:35 »
Steve
mine are self levelling shocks controlled by a manual valve!!! basicaly i just set the height where i want it depending on loads, the self levelling is just a pain tbh I simply connected the airlines to a pressure guage with a shcrader valve on it and can run them as i want!
Omegatoy
Omegatoy
  • UK
Re: more ponies
« Reply #10 on: 15 May 2007, 20:31:51 »
 :o;D
shox dont determine the height mate its the springs that do that, mine are irmsher estate springs which are 40mm lower than standard estate springs but are stiffer in poundage the air shocks raise the ccar for towing purposes as they lift about 60mm on full extension i got the best of both worlds!!
Its a chip that was done on a rolling road in a car with the same software as your ecu mate hence i need the nine digit code on your car to get the correct software version you have, teh chip carries your map! that help?
Omegatoy
  • UK
Re: more ponies
« Reply #11 on: 15 May 2007, 20:34:12 »
 :o
All our chips swere created on a rolling road mate, need the nine digit code on your ecu to check we have the remap available then its just a question of changeing the chip  ;D
miggy
Re: more ponies
« Reply #12 on: 15 May 2007, 20:40:59 »
Thanks, I will take a look tomorow, I was told that my 2002 (52) may not be able to be re-mapped or chipped as it may be a Hybrid ECU???? meaning it cannot be done, would you know from the ecu nine digit code.
How easy is it to install the chip.?? :o :-?
Thanks for your help mate. [smiley=dankk2.gif] [smiley=dankk2.gif]
 :o
azzbo
Re: more ponies
« Reply #13 on: 15 May 2007, 20:57:43 »
i know i sound stupid cow can i tell if i have air supention :-[
Omegatoy
  • UK
Re: more ponies
« Reply #14 on: 15 May 2007, 21:12:11 »
 [depends on whether or not your ecu has a chip carrier or the chip is soldered to the board? nine didgit code can tell us your version yes but havent yet seen a hybrid ecu!! as long as its a 2.5td it should be fine but as always if its a sludge pump you will probably melt teh gearbox !! unless its reasonably new!!
or has been fitted with an ar 35 at some time!!
Omegatoy
Pages: [1] 2 3  All   Go Up
