Author Topic: Explain this fault code?????  (Read 2217 times)
andycuk71
  • Reading
« on: 25 May 2007, 10:44:35 »
 Inlet manifold valve 1 Low voltage
Can anyone explain this fault code please
Re: Explain this fault code?????
« Reply #1 on: 25 May 2007, 10:48:18 »
Its the rear multiram solenoid being reported as iffy, its mounted on the rear of the plenum...
I assume the wire is connected to it....
« Last Edit: 25 May 2007, 10:49:47 by Mark »
andycuk71
  • Reading
« Reply #2 on: 25 May 2007, 11:24:24 »
If vac pipes are not connected up properly could this be that problem??
« Reply #3 on: 25 May 2007, 12:30:02 »
No, the ecu can only check the electrical connections.
andycuk71
  • Reading
« Reply #4 on: 25 May 2007, 12:33:30 »
D'OH
Wire now in eml light off
Cheers
Mark
Admin
« Reply #5 on: 25 May 2007, 17:46:29 »
Car should go a bit better too!  ;D
The Administrator.
