Author Topic: Crack of Doom - the sequel  (Read 2527 times)
ians
  • Reading
« on: 29 May 2007, 14:25:40 »
I replaced the white bushes on my 94 Omega about a month ago and was really pleased it stopped the cracking noise that I'd had as long as I've owned the car.
However, this morning I noticed its returned again (just drivers side) :( :(
I don't see any sign of physical cracking.    Should I still go for the reinforcing plates and will they help?  or does the check strap itself need replacing?
Cheers,
Ian
philayl
  • Wirral, Merseyide
Re: Crack of Doom - the sequel
« Reply #1 on: 29 May 2007, 15:24:26 »
HI, reinforcing plates will only work if the bracket is still secured to the inner and outer door skins. I had to repair mine last weekend, the bracket had broken away from the inner door skin. I left the check strap connected so that I could use force on the door to realign the bracket, I removed the door card and speaker, then pushed the door open until the bracket was in position, then I drilled through the inner door skin and bracket at the top end of the bracket, using a 6.5mm drill bit, (the bracket is about two inches high, so there is enough room to drill a hole without interfering with the check strap mechanism) and fitted a 6mm bolt from the outside and put the nut on the inside of the door, very fiddly but do-able with patience. Then I drilled a smaller hole at the bottom of the bracket and fitted a substantial self tapping screw, greased the check strap and put the door card back on, result no more crack of doom and bracket is as solid as a rock. Hope this helps  :y
« Last Edit: 29 May 2007, 15:25:33 by philayl »
hol666
  • Lechlade, Gloucestershire
« Reply #2 on: 29 May 2007, 19:21:56 »
 :D something I need to do as well, just remember to clean off all the old grease first and slap on plenty of new and all will be silent.  :y
Page created in 0.025 seconds with 20 queries.
