Author Topic: Locked out!!!  (Read 3112 times)
Pete Elite
  • Uxbridge, Middlesex
Locked out!!!
« on: 27 May 2007, 22:41:39 »
Hi all,
       Can anyone help me ?
 I took the battery off my Elite saloon today to charge it up as not having used it for a while, even though i'd removed the neg. terminal.
I had opened the door with the key and after removing battery closed bonnet and pushed all door pins down from inside the car closing d/s/r door last as it would not lock from the outside with key. When i came to unlock the door with key it won't lift the pin up enough to open it :'(.
Has any one had this problem before and is there an answer to it :question.
Cheers,
          Pete :y.
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: Locked out!!!
« Reply #1 on: 27 May 2007, 23:34:38 »
as far as i remember it wil open with the key from drivers door...but you really need to apply some pressure on it...
Pete Elite
Re: Locked out!!!
« Reply #2 on: 27 May 2007, 23:40:21 »
Thanks Markie i'll give it a go, just don't want to snap the key off  :exclamation :'(
Markie
Re: Locked out!!!
« Reply #3 on: 27 May 2007, 23:52:01 »
its a fine line  :-/ but it really needs to be pushed to the point where you think.....this is going to snap... Just dont force it till your red in the face  :y
The Key is a little tougher than you think and it shoudl do the trick. Has happened to a few in the past  :(
Danny
  • Wigan, Greater Manchester
Re: Locked out!!!
« Reply #4 on: 28 May 2007, 01:11:18 »
wont it work in the passenger door?
Pete Elite
Re: Locked out!!!
« Reply #5 on: 28 May 2007, 01:17:33 »
I've not got a key hole on the passenger door, is that not normal then as never thought to check.
 If not normal then a previous owner must have de-locked it :-?.
Pete Elite
Re: Locked out!!!
« Reply #6 on: 28 May 2007, 01:19:46 »
Thanks again Markie, i'll try a little more effort and hope for the best :y.
Re: Locked out!!!
« Reply #7 on: 28 May 2007, 19:46:11 »
I don't know from what date, but Vauxhall de-locked the later preface lift cars. My T reg Astra is the same.
Danny
Re: Locked out!!!
« Reply #8 on: 28 May 2007, 20:00:01 »
shows how much i know!
i'd actually been drinkin when i was online last night, just looked, mine doesnt have a keyhole on the passenger door either! my corsa did, but it wasnt even central locking, which may be why it had a keyhole!
Pete Elite
Re: Locked out!!!
« Reply #9 on: 28 May 2007, 22:51:26 »
 Mine is a 96, and i didn't notice when i bought it that there was no key hole on the pass. side, only when i came to open it from that side because not ever owning a car with a press button entry system before i kept forgetting :-/ :).
I've still to get into the car as it been raining that hard here all day i thought better of it ::)
Damonsal
  • West Sussex
Re: Locked out!!!
« Reply #10 on: 28 May 2007, 23:47:56 »
Having locked myself out of my Omega before it was not possible to use the key even with applying a lot of force.
I ended up unlocking the boot with the key, then using an old coat hanger depress the rear seat buttons and climb through into the cabin and unlock from the inside.   :)
Pete Elite
Re: Locked out!!!
« Reply #11 on: 29 May 2007, 07:39:30 »
 I suppose as a last resort that's what i'll have to do as well :(, wish me luck :).
JohnM
  • Newark on Trent
    • 2.5M Estate
Re: Locked out!!!
« Reply #12 on: 29 May 2007, 20:07:22 »
Pete, still locked out ???
When mine played up [1] I used a *lot* of wd40 equivalent in the key hole.
Next day, opened up like there never was a problem. Try it (if you've the time).
[1] not a power problem per se, but stuck none the less.
« Last Edit: 29 May 2007, 20:08:27 by JohnM »
Pete Elite
Re: Locked out!!!
« Reply #13 on: 29 May 2007, 21:21:29 »
 Thanks John, i'll give it a try :y.
