Author Topic: Dash Lamp Bulbs  (Read 2830 times)
ians
  • Reading
Dash Lamp Bulbs
« on: 30 May 2007, 15:58:01 »
Can anyone advise which lamp bulbs (the 2W push fit ones x3) are used behind the instruments (speedo etc).
Is it these?
http://www.autobulbsdirect.co.uk/product.php?productid=16943&cat=588&page=4
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Dash Lamp Bulbs
« Reply #1 on: 30 May 2007, 16:02:17 »
Is it these?
Got to do mine too, but, I am sure i read on here sometime ago that they have a black body on the bulbs that go behind the clocks.
Daz
omegalyn
Re: Dash Lamp Bulbs
« Reply #2 on: 30 May 2007, 16:08:51 »
I don't think that thay are the ones, when I took my dash out to fix the TID, the bulbs had a flat peace at the bottom with two prongs that make a contact when you twist in, I got mine in Halfords for the TID (509T) but the ones behind the clocks are bigger in size and are green.
http://cgi.ebay.co.uk/led-286t-509t-dash-bulbs-kit-white-vauxhall-volvo-vw_W0QQitemZ320116472068QQihZ011QQcategoryZ28646QQrdZ1QQcmdZViewItem
« Last Edit: 30 May 2007, 16:17:28 by omegalyn »
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Dash Lamp Bulbs
« Reply #3 on: 30 May 2007, 16:12:16 »
Is it these?
I will go and take one of mine out and post a picture :y
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Dash Lamp Bulbs
« Reply #4 on: 30 May 2007, 16:34:58 »
This is the bulb from behind the dash in between the Temerature Gauge and Rev Counter, you can see mine is blown ;D
It says on the bulb OS 12/2w 9B
« Last Edit: 30 May 2007, 16:37:13 by Loo-knee »
ians
  • Reading
Re: Dash Lamp Bulbs
« Reply #5 on: 30 May 2007, 17:09:02 »
I wonder if its these then
http://www.autobulbsdirect.co.uk/product.php?productid=16651&cat=588&page=2
did you find three of them - its the ones lighting up the main dials I need.
I've got one car with its climate panel in pieces so don't really want to take t'other one apart!
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Dash Lamp Bulbs
« Reply #6 on: 30 May 2007, 17:15:58 »
 ;D ;D
I need to do the passenger climate bulb too ;D
may just leave that though, you have to take out the radio and cage and ram your hand up behind to pull or push a lever  :o
ians
  • Reading
Re: Dash Lamp Bulbs
« Reply #7 on: 30 May 2007, 17:20:23 »
 ;D ;D
Indeed you do!  Did that at the weekend.  There are a few gotchas along the way which I'll happily helpout with when you do it.
How is it getting the instrument panel out?  The electrical connector sounds a bit odd.
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Dash Lamp Bulbs
« Reply #8 on: 30 May 2007, 17:48:12 »
 ;D ;D
Takes about 15 mins to get it off think i did it and took the picture of the bulb and got it on here in about half an hour :y
Pete Elite
  • Uxbridge, Middlesex
Re: Dash Lamp Bulbs
« Reply #9 on: 30 May 2007, 23:56:18 »
Hi,
   I think you'll find that the bulb in the picture is in it's yellow holder and pulls out and is a type 501,(looks like an old flash bulb) :).
 Hope this helps,
                       Pete :y.
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Dash Lamp Bulbs
« Reply #10 on: 31 May 2007, 22:59:23 »
Here you go Ians got a new bulb this morning this is what they look like naked ;D
ians
  • Reading
Re: Dash Lamp Bulbs
« Reply #11 on: 01 June 2007, 09:53:01 »
Brilliant thanks LK.  Was that from a dealer?  How much (I'm expecting pennies for a 501 style)
Were there three of them in the panel?
Cheers
Ian
BTW the sealant has worked brill - ta!
BazMV6
  • Silverstone
Re: Dash Lamp Bulbs
« Reply #12 on: 01 June 2007, 12:12:14 »
Reading this with interest - I need to do same at some point...
This space left blank for your own message...
ians
  • Reading
Re: Dash Lamp Bulbs
« Reply #13 on: 01 June 2007, 12:37:40 »
You'd think dealers would have these aplenty.
Climate panel bulbs (you need 5 of them)
' oh we've got 3, and I can see there is another one in Newbury....' >:(
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Dash Lamp Bulbs
« Reply #14 on: 01 June 2007, 15:46:38 »
Cheers
Ian
Glad the sealer worked :y
Yes bulb from main dealer it was 60 pence.... Now your asking i have slept since then but yes i think there were three,::) but only replaced the one as it real easy to get at anyway.
Daz :y
« Last Edit: 01 June 2007, 15:48:30 by Loo-knee »
