Author Topic: sunroof problem  (Read 2411 times)
chelskifl
  • chertsey
  • Yaba Daba Do Omega I Luv U
sunroof problem
« on: 31 May 2007, 23:52:13 »
i had a majar problem last week a rock went under my car and for some reason the alarm horn went dead short and burnt out.. i have a second hand one to put in soon.. but for some reson now my sunroof will not open i have checked the fuse which sems ok,, so im wondering weather its the relay ,, doas anyone know where it is (omega elite estate 1997) or im grabbing at straws here.... somthing to do with the horn burning out. every thing else electrical works seems strange because it only stopped working after the rock under the car... heeelp
STMO123
Re: sunroof problem
« Reply #1 on: 02 June 2007, 08:32:18 »
btt
Admin
Re: sunroof problem
« Reply #2 on: 02 June 2007, 10:10:55 »
Thanks for that Steve. :)
Ok, first of all check the fuse. http://www.omegaowners.com/forum/YaBB.pl?num=1161602008
Now if that is ok, try the following:
With the controller in the sunroof closed position, push the controller in (rather than turn it) and hold it to the count of 3. If there is power there you will hear a few clicks as the sunroof open slightly then closes.
If that worked, turn the controller to fully open and repeat.
Now return to fully closed and hopefully it will work.
The Administrator.
