Author Topic: where is my thermostat????  (Read 6168 times)
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: where is my thermostat????
« Reply #15 on: 31 May 2007, 17:43:18 »
beware of garages promising cambelts and tensioners being done...unless they can prove it or have a copy invoice....and if they cant id be getting that, and the water pump done.
Bernard
  • Bimingham-Near NEC
« Reply #16 on: 31 May 2007, 22:02:10 »
Unfortuneately they do not do the sensibly thing and replace the Water Pump automatically while it is all stripped down to do the Timing Belt. Great pity because the Pump is only about £25 but it means a Major strip down to do it.Wishing you the Best and Hope it has been done because if it does leak it ruins the Timing Belt and Adjuster and can lead to Major Engine Damage!!!
Nothing gives you a oooooh like a good old Vauxhall.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #17 on: 31 May 2007, 22:45:12 »
Could you not come to the lakes meet, there will be loads of people dying to get under the bonnet of everyones car :y
You would get a proper job done at the price of your parts ;)
Oh and a can of Beer ;D
« Reply #18 on: 31 May 2007, 23:22:22 »
Just a thought after reading your other thread. Are you talking about the thermostat that controls the electric cooling fan or the thermostat controlling water flow to the radiator?
The fan thermostat is below the top radiator hose on the passenger side of the radiator, and much easier to get to.
donna-marie
  • Leeds Westyorkshire
« Reply #19 on: 02 June 2007, 14:11:42 »
after 3 garages told me it was the thermo turned out it's the water pump as most of you said, i did tell a local garage this, he is fitting it Tuesday. Any ideas where it is and how long should it take. the guy charges £20 hr as he does it after hours?
 ;D
« Reply #20 on: 02 June 2007, 14:31:10 »
 ;D
I could change a V6 water pump in less than an hour
« Last Edit: 02 June 2007, 14:31:25 by JamesV6CDX »
donna-marie
« Reply #21 on: 02 June 2007, 14:32:38 »
fast worker eh? haha thanks for that will keep that in mind
« Reply #22 on: 02 June 2007, 14:34:20 »
fast worker eh?
And then some...
Not very quick at working on cars though ;) ;D
Seriously though, if someone quotes any more than 2 hours to change this water pump, they're either not competent enough, or are after the ££ :)
donna-marie
« Reply #23 on: 02 June 2007, 14:40:21 »
cheer hun, i really do appreciate it
« Reply #24 on: 02 June 2007, 14:43:20 »
If you were closer, I'd do it myself :(
