Author Topic: DIS pack failure  (Read 2800 times)
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
DIS pack failure
« on: 02 June 2007, 14:28:12 »
Doug just called me, apparently his DIS pack has failed (no.5 no spark - checked with different leads and plugs which are new)
How much do they go for at vx on TC?
Also I remember his DIS was mounted vertically whereas mine is horizontal and much easier to access - is this normal?
Re: DIS pack failure
« Reply #1 on: 02 June 2007, 14:32:32 »
I think the vertical / horizontal mounting depends on the Age of the car...
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #2 on: 02 June 2007, 14:36:40 »
i have just paid £88 for a non gen one, i was stuck and needed it quick.
saying that it is a Bosch part, my thinking is that it is as good as gen.
mine was the horizontal one, wasn't too bad to fit once i hed stripped out half the engine
« Reply #3 on: 02 June 2007, 14:44:04 »
Were Bosch one's not used as standard?
Admin
« Reply #4 on: 02 June 2007, 15:12:51 »
Bosch are standard.
Think they are around £75 on t/c (book in shed, can't be bothered to go check!)
« Last Edit: 02 June 2007, 15:13:17 by admin »
The Administrator.
« Reply #5 on: 02 June 2007, 16:13:59 »
Bosch are standard.
You can get them from Scrappys, we did for TB1... although the DIS was not the problem in the end. Just remember to pay for it as we forgot  ::)
JasonH
« Reply #6 on: 02 June 2007, 19:44:08 »
They're cheaper on Ebay - around £70. They're nearer £100 on TC.
If it's only one plug that's strange. The DIS pack only has 3 coils so there's a wasted spark which means you usually lose two cylinders if a coil fails.
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #7 on: 02 June 2007, 20:23:52 »
Bosch is standard  - although there are 3 types.....trade card is £100 or so exc VAT, best get it from ebay - theres a particularly good seller - vauxhallpartswarehouse - that do lots of vx stuff cheaper than trade ( i got my oil cooler, water pump off them)
Im in the process of removing dis pac - cant be arsed trying to get the fourth bolt in that holds it in place - so far havent found it too bad ( horizontal mounted)
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
« Reply #8 on: 02 June 2007, 20:51:09 »
Bosch are standard.
It is for a 2.2 but £100 for V6  ;)
gnasha
  • Kettering
« Reply #9 on: 02 June 2007, 22:11:27 »
has vauxhallgot a remote for these things as it seems everyones is going at same time :o changing my plugs and leads tomoz if weather ok and if that not sort mine then its dis pack for me 2 :(
we have 1984 landrover ,1990 rangerover 3.9lpg and 2.5v6 elite 1997 but told it's a 98 spec
michael_de
  • dumbartonshire
« Reply #10 on: 02 June 2007, 23:08:55 »
i cant believe im reading this , today my mv6 started running rough and after elimination it turns out no5 isnt firing i changed the lead with no avail , i was confused as i know its wasted spark however from experience on fords i know the zetec wasted spark coils commonly drop no2 . so its a coil pack for me too im afraid .
Markjay
  • London
« Reply #11 on: 03 June 2007, 00:16:02 »
Note also the differences in the location and shape of the low-voltage connector.
« Last Edit: 03 June 2007, 00:20:27 by markjay »
Alas, no more Omegas....
Page created in 0.022 seconds with 20 queries.
