Author Topic: headlight taillight  (Read 2377 times)
gnasha
  • Kettering
headlight taillight
« on: 01 June 2007, 23:09:31 »
on comp screen iam getting headlight taillight  with the check light on but all lights are working ok any idea's
we have 1984 landrover ,1990 rangerover 3.9lpg and 2.5v6 elite 1997 but told it's a 98 spec
Re: headlight taillight
« Reply #1 on: 01 June 2007, 23:10:39 »
I get the same with the Elite - not yet investigated
Intermittent connection on one light? Faulty control unit? I'll be interested in the outcome...
Admin
« Reply #2 on: 01 June 2007, 23:12:58 »
Usual culprit is non standard rear lights (Bosch in particular). They run at a slightly different wattage to the Vx ones and it triggers the warning.
The Administrator.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #3 on: 01 June 2007, 23:20:35 »
Had the same thing come up Check Taillights/Headlights on computer... check all that are in that rear cluster, think it turned out to be a rear foglight or reverse light was only a small one anyway :y
« Last Edit: 01 June 2007, 23:20:52 by Loo-knee »
gnasha
  • Kettering
« Reply #4 on: 02 June 2007, 11:10:52 »
only comes on when i turn on my lights goes off when i turn them off but will check connections anyway
Craig_R
  • Watford
« Reply #5 on: 02 June 2007, 11:25:13 »
I had this.
Tracked it down to a dip head lamp bulb 10 quid later from Halfrauds problem gone.
Craig
Mod's
[To be Fitted]Reverse Sensors
gnasha
  • Kettering
« Reply #6 on: 02 June 2007, 22:13:46 »
sorted was d/s/r/ side light did not no there was 2 bulbs in there for 1 job
Markjay
  • London
« Reply #7 on: 03 June 2007, 00:25:54 »
Yes - my previous 'meega was extremely find of Ring Automotive bulbs which are supposed to some cheap pattern rubbish, but did not like too much the more established brand...  :o luckily my current car is not that fussy.  ;D
But before jumping to conclusions, don't forget to check the bulbs on the inside of the boot lid - easily overlooked...  :y
Alas, no more Omegas....
« Reply #8 on: 03 June 2007, 08:00:21 »
No monitored bulbs in bootlid ;)
Markjay
  • London
« Reply #9 on: 03 June 2007, 09:34:59 »
[size=8]
I knew that... [/size]  :-[
 ;D
« Last Edit: 03 June 2007, 09:35:23 by markjay »
