Author Topic: sunroof  (Read 2217 times)
prr
  • paignton devon
  • dont be scared to take it apart
sunroof
« on: 01 June 2007, 22:30:45 »
can anyone help with a problem my sunroof dont seem to hold its memory to fully close the sun roof from the fully open or the fully tilted position
its fine when opening to the two positions its just when you put the switch in the close postion from the fully open position it closes about half way or from the tilted position it fully closes then it opens slightly and rests in that position ive tried to re-program it its ok for a few days then goes back to being the same again
 im sure theres an answer out there
Admin
Re: sunroof
« Reply #1 on: 01 June 2007, 23:18:19 »
When you say you have reset it, I take it you have pushed in and held the controller in the fully closed, and then the fully open position?
If it is forgetting after a few days having done this, I suspect an intermittant power loss.
Are the windows working on the one touch fine?
The Administrator.
prr
  • paignton devon
Re: sunroof
« Reply #2 on: 02 June 2007, 00:08:10 »
hello laidback66 glad to see your here with your wisdom again you helped me last year with mark dtm to solve a problem i had before so here i am to test your knowledge
yes ive held the swith in for the reseting of the sunroof and the window one touch is working fine had no problems there its just the sunroof  seems to loose its memory after a few days :-?
Admin
Re: sunroof
« Reply #3 on: 02 June 2007, 10:12:20 »
pm answered :)
The Administrator.
prr
  • paignton devon
Re: sunroof
« Reply #4 on: 04 June 2007, 21:45:52 »
well just to let you all know that the ghost of the sunroof has gone so i will leave it be for now and see what happens :)
