Author Topic: Please Help , ok then ive  (Read 2567 times)
wayneo
  • Cambridgeshire
  • Car and ice nut
« on: 04 June 2007, 18:55:14 »
done the paperclip test as my EML is on and its come back with
code 38 Oxygen sensor circuit Voltage high so then any ideas please peeps.
« Last Edit: 04 June 2007, 20:06:38 by wayneo »
wayneo
  • Cambridgeshire
  • Car and ice nut
Re: Please Help , ok then ive
« Reply #1 on: 04 June 2007, 20:07:48 »
anyone  :question :question :question
I just need an idea of where to start looking.
thx wayne.
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #2 on: 04 June 2007, 20:46:40 »
i would have said lambda sensor, that is what i know as ox sensor
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
« Reply #3 on: 04 June 2007, 20:55:02 »
What symptoms do you have Wayne?
Oxygen or Lambda sensor monitors fuel/air mix after it's passed through the engine.
It can often be a sympton such as an air leak in the air intake or it may be a failed sensor.
Is the EML on all the time?
wayneo
  • Cambridgeshire
  • Car and ice nut
« Reply #4 on: 04 June 2007, 21:03:15 »
EML is on all the time it dont idle too well after the choke has cut out and one other thing it had a new exhaust fitted badly from the looks of it as i think its leaking dont know if that would be a factor and tonight i also noticed the airflow sensor is fitted so well it fell off when i touched it  :o ::) will push that back in tommorrow.
thanks in advance for any help / advice.
wayne.
« Reply #5 on: 04 June 2007, 22:24:59 »
it may not be the lamda - just because ecu thinks it is...
air intake leaks, and exhaust leaks are possibilities...
« Reply #6 on: 05 June 2007, 08:47:58 »
Yep, start at the air filter housing and work through to teh inelt manifold checking all pipes and vac hoses as you go...
Remember that a fault code gives little more than an indication of why the ECU is not happy.....it does not always describe the exact component at fault.
Craig_R
  • Watford
« Reply #7 on: 05 June 2007, 09:39:18 »
Also Check you cables attaching to the lambda sensor when i changed mine over all 4 wires had bare metal wire showing the plastic outer coating had been rubbed away, this would cause a short and show the sensor as not working. If its not that double check the connector i have heard some of the pins in the connector can get pushed back
Craig
Mod's
[To be Fitted]Reverse Sensors
wayneo
  • Cambridgeshire
  • Car and ice nut
« Reply #8 on: 05 June 2007, 12:12:02 »
thanks everyone i will go get my hands dirty.  :y
