Author Topic: severe coolant loss MV6  (Read 2075 times)
Jame5m
  • Wirral, England
« on: 05 June 2007, 17:01:03 »
ok guys, ive driven all the way to sunny bristol, no problems whatsoever,
this morning though im showing low coolant so i top it up, (50/50 mix)
showing low coolant again within 3 miles.....  its pissing out from somewhere towards the back of the engine,
no clouds of smoke, no oil in the water or water in the oil...
any idea's?
"Heaven don't want me and hell is scared of a takeover bid"
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: severe coolant loss MV6
« Reply #1 on: 05 June 2007, 17:11:06 »
any idea's?
HBV, Coolant bridge Seals, Oil Cooler Plate Seal :y
Jame5m
  • Wirral, England
« Reply #2 on: 05 June 2007, 17:11:54 »
expensive/ hard job to do?
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #3 on: 05 June 2007, 17:20:24 »
The HBV cost me about £30, the coolant bridge seals are pence, the coolant plate seal cost about £10, but while i was there i changed the oil cooler too which was £95.
To get the oil cooler plate out was a bit of a pain, I was hoping to get it out without removing the oil cooler, but I couldn't as the space is very tight in there... :y
Jame5m
  • Wirral, England
« Reply #4 on: 05 June 2007, 17:21:40 »
id love to do it myself but im working away in bristol so its off to the vaukies agent down the road,
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #5 on: 05 June 2007, 17:25:14 »
Sounds like HBV if anything...  they rarely look faulty when removed, so don't be fooled by its looks......  easy to do with scuttle off..
Go for it!! :y
« Reply #6 on: 05 June 2007, 17:45:05 »
Big coolant loss is heater bypass valve as a rule.....although we seem to have had a few coolant plates recently....
ians
  • Reading
« Reply #7 on: 05 June 2007, 17:50:59 »
My monies on HBV too.  If you've got some tools handy not too bad a job, otherwise its a £30 (trade?) part and about half an hour labour.
« Reply #8 on: 05 June 2007, 19:50:18 »
HBV is likely if its a big leak - take scuttle off and you should see it leak.
If the cooler plate has a hole, that will mean a big leak from the valley....
« Reply #9 on: 05 June 2007, 19:55:36 »
At that rate of loss, I doubt it's bridge seals
Most likely, is going to be HBV or a split hose at the back of the engine
After that, it will be in the valley area, possibly a hole in the cooler plate, but not all that common
