Author Topic: I need acouple of Torque Settings  (Read 2082 times)
Craig_R
  • Watford
« on: 05 June 2007, 11:02:07 »
With everyone going to the lakes this weekend i thought i would ask this early as i dont want to be stuck changing a few bits this weekend coming.
Rear Shocks (If I do Them)
WishBones
Track Rods Both ends
Brake Disks
Steering Idler (If I Need to do it)
I know there are acouple of settings on the forum, IE brake stuff.
Thanks  :y :y
Mod's
[To be Fitted]Reverse Sensors
omegalyn
Re: I need acouple of Torque Settings
« Reply #1 on: 05 June 2007, 11:40:35 »
Hi there
I shall look in Haynes tonight after work if no one els posts them.  :y
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #2 on: 05 June 2007, 17:30:08 »
Recommended Torque Values
Caution
Angle specifications refer to yield limit controlled fastening bolts, which may only be used once. Tighten fastening bolts only with the appropriate torque and then turn further by the specified angle.
  Nm
Exhaust gas recirculation valve and front bracket to auxiliary aggregates holder
 20
Airbag unit to steering wheel
 8
Outer tie rods to centre tie rod
 60
Electro-hydraulic converter to steering gear
 2.9
Retaining bow, fluid reservoir to spring strut dome
 7
Retaining strap on power assisted steering pump
 20
Retaining shackle to cylinder block
 20
Bracket, hydraulic modulator to front frame side member
 10
Bracket, idler to front frame side member
 55 + 75° + 15°
Brackets, cooling loop to strut
 4
Power assisted steering hydraulic lines to power assisted steering pump
 28
Power assisted steering hydraulic lines to power assisted steering pump (diesel engine)
 37.5
Clamp bolt to steering gear
 22
Clamp bolt to steering shaft
 22
Steering gear to front frame side member
 55
Steering wheel to steering shaft
 20 1)
Steering arm to steering shaft
 160
Steering column with bracket to bulkhead
 22
Idler to bracket
 60
Centre tie rod to steering arm
 60
Centre tie rod to idler
 60
Engine damping block
 40
Nut, bracket – steering column support
 22
Auxiliary aggregates holder to cylinder block
 40
Power steering pump to support (X 20 DTH)
 20
Power assisted steering pump to auxiliary aggregates holder (4 cylinder engine)
 25
Power assisted steering pump to auxiliary aggregates holder (6 cylinder engine)
 20
Belt pulley to power assisted steering pump
 20
Return line to engine transport shackle
 4
Tie rod end to steering knuckle
 60
Tie rod end to centre tie rod
 60
Steering column support to bracket
 22
Sleeve nut, power assisted steering hydraulic lines to screwed socket
 18
Sleeve nut, power assisted steering hydraulic lines to steering gear
 28
Front exhaust pipe
 20
Heat shield to upper steering gear
 8
Heat shield to lower steering gear
 15
Hydraulic unit heat shield to holder
 8
1 ) Tighten fastening nut to 20 Nm/15 lbf. ft., then release by 90° and re-tighten to 20 Nm/15 lbf. ft.
Hope this helps  DC 8-)
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #3 on: 05 June 2007, 17:31:30 »
Also:::::
Recommended Torque Values – Brakes
Caution
 Nm
Cover plate to steering knuckle (front wheel brake)
 4
Brake servo to support (nuts)
 21
Front brake caliper to brake carrier
 30
Rear brake caliper to semi-trailing arm
 80
Brake disc to front or rear wheel hub (lock bolt)
 4
Bracket to steering knuckle
 95 + 30° + 15 1)
Brake backing plate to rear axle
 4
ESP pressure sensor to hydraulic modulator
 20
Bleeder screw to brake caliper
 9
Yaw rate/acceleration sensor to retaining plate
 8
Parking brake lever to vehicle underbody (bolts)
 20
Bracket for hydraulic modulator to front frame side member
 10
Propshaft centre bearing bracket to vehicle underbody
 20
ABS/TC control unit bracket to hydraulic modulator
 8
Brake master cylinder to brake servo
 22
Rear exhaust pipes to catalytic converter
 25
Banjo bolt, brake pressure hose to brake caliper
 40
Hydraulic modulator to bracket (nuts)
 8
Fork lock nut to brake servo piston rod
 21
Centre exhaust pipes to catalytic converter, V6
 25
Pedal axle to pedal support
 18
Pedal support to bulkhead
 20
Wheel to wheel hub
 110
Wheel sensor to rear differential
 8
Wheel bolts to front/rear wheel hub
 110
Parking brake telltale switch to parking brake lever
 2.5
ABS/TC control unit to bracket
 1.5
Union nut to intake manifold
 18
Union nuts for all brake lines
 16
Hydraulic modulator heat shield to bracket
 8
1) Insert new fastening bolts with locking compound.
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #4 on: 05 June 2007, 17:32:54 »
and for good measure_____
Caution
Torque values deal with yield limit-controlled retaining screws which may be only be used once. Only tighten retaining screws to the appropriate torque and then continue to tighten by the amount specified.
  Nm
Drive shaft to wheel journal flange
 50 + 60° + 15°
Brake calliper to semi-trailing arm
 80
Brake disc to wheel hub
 4
Brake carrier to semi-trailing arm
 50 + 30° + 15°
Damping blocks to vehicle underbody
 65
Damping blocks to rear axle body
 90 + 30° + 15°
Cover on locking differential housing
 14
Single disc joint to propshaft flange M10 x 1.25 (Torx)
 50 + 45° + 15°
Single disc joint to propshaft flange M12 x 1.5
 95
Single disc joint to transmission/rear differential flange M10 x 1.25 (Torx)
 50 + 75° + 15°
Single disc joint to transmission/rear differential flange M12 x 1.5
 95
Bracket to rear differential
 90 + 45° + 15°
Bracket to vehicle level control sensor
 4
Centre bearing bracket
 22
Centre bearing bracket to vehicle underbody
 20
Bracket with level control sensor to rear axle body
 12
Bracket with compressor to wheel well
 12
Rear differential, rear, to front axle body
 90 + 30° + 15°
Rear differential, front, to rear axle body
 100 + 75° + 15°
Rear differential cover to rear differential
 60
Rear axle body damping bushing to vehicle underbody
 125
Clamps to auxiliary control arm
 15
Level control system compressor to bracket
 4
Swing arm to semi-trailing arm
 20
Wheel on wheel hub
 110
Wheel sensor on transmission cover
 7
Wheel journal flange to wheel journal
 3001)
Semi-trailing arm to rear axle body
 100
Headlamp range control sensor to rear axle body
 10
Stabiliser to rear axle body
 22
Shock absorber to semi-trailing arm
 110
Shock absorber fastening nut on piston rod
 20
Strut for rear axle body to vehicle underbody
 65
Ring gear to differential/limited slip differential M10
 75
Ring gear to differential/limited slip differential M12
 115
Closure bolt of the rear differential
 22 + 90° + 180°
Front muffler to catalytic converter
 25
Auxiliary control arm to rear axle body
 901)
Auxiliary control arm to semi-trailing arm
 45
1) use new self-locking fastening nut
  DC :y
omegalyn
« Reply #5 on: 05 June 2007, 18:31:18 »
Glad to see Dave has done a great job, just wanted to see if this works, new to photobucket :-?  scaned from 1994 to 1999 haynes manual.
« Last Edit: 05 June 2007, 18:35:19 by omegalyn »
Craig_R
  • Watford
« Reply #6 on: 05 June 2007, 19:42:25 »
WOW thanks dave c and Omegalyn
I have all the Torque settings i need to strip the car now  :y :y :y
Thanks Again  :)
Craig
Mod's
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #7 on: 05 June 2007, 20:00:21 »
Thanks Again  :)
Craig
Our pleasure...
DC
