Author Topic: elite head  (Read 1248 times)
oli3lv6
elite head
« on: 05 June 2007, 19:37:09 »
hy guys on way to pv show my head went been to independant dealer also a good mate used the dye and water is mixing ans system pressurising so i need to no what this job will cost and how much indivual parts head set belt kit will cost and if anyone has a couple of good heads let me no just in case cheers
Re: elite head
« Reply #1 on: 05 June 2007, 19:53:04 »
Is water getting in the oil, or oil getting in the water? Done a compression test? V6 Head gasket failure is very rare, I've only seen it on one Omega ever.
What year, and engine size?
If you do need replacement heads, I have some of a prefacelift 2.5 going cheap... but hopefully (for you) you won't need them...
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: elite head
« Reply #2 on: 05 June 2007, 23:44:39 »
Anyway,as prev said  unless you have water getting into the oil i think it is the oil cooler. regards Gary. :y
« Last Edit: 06 June 2007, 07:11:07 by Auto_Addict »
Jaguar XJ6
Markjay
  • London
Re: elite head
« Reply #3 on: 06 June 2007, 00:06:02 »
On 4-cylinder engines, i.e. 2.0 8V, 2.0 16V, and 2.2 16V it is not a huge job. A memeber here had his done for around £350 by a mechanic after being quoted around £500 from an independent. Vauxhall would probably charge £1000+.
On V6 this is a big job, access to remove the heads is not good so very work intensive. In my opinion on a V6 this paying garage money would be uneconomical, so only makes sense really as DIY.
Having said that, as mentioned above head gasket failure is rare on the 4-cylinder engine and even rarer on the V6.
The V6 has an oil cooler which often fails giving symptoms similar to head gasket failure. As a rule, oil in water is oil cooler, water in oil is head gasket.
Check for exhaust gasses in the header tank (at a garage or MOT station), and also carry-out a compression test.
Alas, no more Omegas....
