Author Topic: Headlights  (Read 1813 times)
rands100
  • Kent
Headlights
« on: 05 June 2007, 09:33:59 »
The head lights on my 97 meega has what seem like plastic lenses that have gone opaque. I read somewhere about rubbing them (wet and dry??) then polishing them.
Does this work or will I make them worse.
Thanks
Richard
Re: Headlights
« Reply #1 on: 05 June 2007, 09:48:54 »
It works very well.....I start with 400 grit, then 800 and then 1200 (all used wet) followed by a good polish with G3 (although T-cut also works)
Lordmpl
  • Norwich, Norfolk, UK
  • 2.5 V6 Auto CDX - Big Bertha
Re: Headlights
« Reply #2 on: 05 June 2007, 10:13:53 »
Hi, mine were dark yellowish colour when i got my omega 1994, I used a buffer and rubbing compound on em, they are crystal brite now.
Mark
I Love my Omega, wanted it for so long, now it's in my grasp, it's not getting away!!
ians
  • Reading
Re: Headlights
« Reply #3 on: 05 June 2007, 10:15:26 »
I used Tcut on mine (no sanding) and it did make a big difference.
gizza
  • baildon essex
Re: Headlights
« Reply #4 on: 05 June 2007, 13:34:35 »
used t cut no rubbing, and put phillips 50% brighter bulbs in them and there great now
rands100
  • Kent
Re: Headlights
« Reply #5 on: 06 June 2007, 09:07:21 »
Started to rub with 1200 grit and t cut - looks like its gonna work well. I was going to ask about changing the lamps to something like 50% brighter. Do they make that much differance?
Richard
Re: Headlights
« Reply #6 on: 06 June 2007, 09:09:18 »
Yes, well worth while.
If you want to go the whole hog then run new 0V connections back to the main 0V point under the battery.
gizza
  • baildon essex
Re: Headlights
« Reply #7 on: 06 June 2007, 10:44:26 »
the phillips 50+ plus bulbs are a very good upgrade for the lights, got mine from ebay a complete set 2 for each side including postage came to £24
