Author Topic: mv6 no spark  (Read 1607 times)
mv6knackered
mv6 no spark
« on: 05 June 2007, 16:50:07 »
how's it going dudes, total newbie here with a bit of a problem and i'm hoping your vast pool of knowledge could help me solve it.
i have an mv6 which has lost it's spark on the left hand cylinder near the rad. i checked the lead with a replacment and it's not that (or the plug). i'm lead to believe the coil pack fires in pairs which is why it's confusing as the other 5 seem to work ok? (which cylinder is that one paired with?)
any ideas would be welcome as it's a pain in the @rse to get the DIS pack out (which is what i'd try next)
cheers all   :y
Re: mv6 no spark
« Reply #1 on: 05 June 2007, 17:40:55 »
So it sounds like front left as in number 1 cylinder which is paired with number 4 (its 1-4, 2-5, 3-6)....
Although they are in pairs, if the secondary side of number 4 was to short to 0V (chassis) then you would loose just the one plug.
mv6knackered
Re: mv6 no spark
« Reply #2 on: 05 June 2007, 17:49:42 »
sounds like it could be the DIS pack after all. which one is number 4 cylinder...back right?
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
Re: mv6 no spark
« Reply #3 on: 07 June 2007, 21:22:46 »
no. 4 is middle plug on nearside bank (assuming you are in the UK!!).
« Last Edit: 07 June 2007, 21:23:20 by sounds2k »
