Author Topic: Heavy steering  (Read 2147 times)
NML
Heavy steering
« on: 08 June 2007, 19:00:59 »
The Steering keeps going heavy. It doesn't really happen at a certain time, just every now and then. When it does go heavy it as if the engine is off but it isn't, and its mainly at slower speeds.
Thanks in advance
Danny
  • Wigan, Greater Manchester
Re: Heavy steering
« Reply #1 on: 08 June 2007, 19:49:02 »
any dash lights coming on?
NML
Re: Heavy steering
« Reply #2 on: 08 June 2007, 20:25:17 »
Nope all the dash light are off when it happens
geoff
  • thornaby,stockton on tees
Re: Heavy steering
« Reply #3 on: 08 June 2007, 20:32:52 »
have you checked power steering level ,when cold should be on low mark dip stick on cap,when engine is hot should be on higher mark,also check drive belt could be slipping,failing that could be pump going for a burtons :y :y :y
