Author Topic: plastic headlamps  (Read 3018 times)
phil her up
  • Kent
plastic headlamps
« on: 10 June 2007, 13:24:23 »
I don't know if this is normal but my headlamp glasses appear to be PLASTIC >:( when I bought the car I did notice they were a bit opaque & scratched.
Oh & I know this sounds daft but does my car have a immobilser fitted, how do you tell? any info from my fellow oofers would be appreciated ;)
I love the smell of welding in the morning
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
Re: plastic headlamps
« Reply #1 on: 10 June 2007, 14:16:20 »
plastic headlamp lenses are normal ... less likely to get smashed by stones! Seem to remember someone recommending the use of brasso to clean them ...
AFAIK all omegas have immobilisers - if you pull the blade off the rest of the key there is a small transponder chip in the bottom of the blade section.
I don't think GLS spec models have an alarm as standard, though.
ians
  • Reading
« Reply #2 on: 10 June 2007, 22:40:09 »
TCut works a treat on the pre minifacelift lenses (pre 98 I think) that go 'yellow'.
Lordmpl
  • Norwich, Norfolk, UK
  • 2.5 V6 Auto CDX - Big Bertha
« Reply #3 on: 11 June 2007, 09:16:08 »
My lenses were all yellowy when i got the car, Used an electric buffer and some t-cut, they are lovely and crytal clear again.   ;D ;D ;D
I Love my Omega, wanted it for so long, now it's in my grasp, it's not getting away!!
Dazzler
  • Haverhill, Suffolk
« Reply #4 on: 11 June 2007, 09:27:54 »
I used G3 by hand, t-cut was making me leak to much ;D
« Reply #5 on: 11 June 2007, 10:03:40 »
Yes, like most modern cars, plastic.
What year is your car?
OMEGA VXR
  • Leicester
  • I love my Omega
« Reply #6 on: 11 June 2007, 12:23:41 »
Talking of headlights can you take the lenses off of the face lift omegas? Ive had a quick look and there seems to be a number off plastic clips!
The reason I ask is Ive seen a couple off cars with the insides (chrome bit) sprayed mat black. it looks  good, but is it legal?
[img name=signat_img_resize]http://i159.photobucket.com/albums/t146/WJones_2007/Lee%20Photos/DSCF0113-2.jpg[/IMG]  [img name=signat_img_resize]http://i159.photobucket.com/albums/t146/WJones_2007/Lee%20Photos/DSCF0114-1.jpg[/IMG]
phil her up
  • Kent
« Reply #7 on: 11 June 2007, 17:31:12 »
to the boy, it's a 1996 on a N ;    thanks to members suggesting metal polish, I will try it ;) also the immobiliser question, my keys havn't got the removable bit but I have the egg shaped plipper so have I got a immobiliser or not? :-/......phil
« Reply #8 on: 11 June 2007, 17:34:07 »
You have a decent immobiliser on that, Thatcham approved (can't remember if cat1 or 2). Chip in key is read by reader in ignition, and if the immobiliser ecu is happy this is an authorised key, it sends a unique code to engine ECU saying it has authority to start.
rands100
  • Kent
« Reply #9 on: 11 June 2007, 22:15:19 »
My headlamps were really bad, yellow, scratched and had had stickers on at some point. I used 1200 grit wet and dry a new sheet) then 1200 grit again but well used. Then Halfords rubbing compound then T cut then polish. The headlamps are now crystal clear. I also bought 50% brighter bulbs.
For the first time since Ive had the car I can see where Im going!!!!
Richard
miggy
« Reply #10 on: 11 June 2007, 22:37:07 »
Seen the clips on mine but I dont think the lenses come off, as for spraying the chrome backs black, this would make you beam less efficient as the chrome is not for cosmetic reasons, it acts as a reflector, dont know if its illegal but most likely be an mot failure.
no doubt someone on the forum will know for deff.
 :y :y
« Reply #11 on: 11 June 2007, 23:06:15 »
If the headlights are 'projector' type, the silver bit is not used as a reflector.  If they are 'reflector' type, then they are...
miggy
« Reply #12 on: 11 June 2007, 23:08:16 »
Whats the difference TB
 :question :question
sounds2k
« Reply #13 on: 11 June 2007, 23:23:23 »
easiest way to tell projector and reflector - if you can see the bulb in the middle ie, both halves of the light - main and dipped beam) look identical then it's a reflector. If you see what looks like a big glass golfball in the dipped beam section, then you have projector (or HID) headlights ...
The lenses DO come off ... but they are bonded on with a black mastic type sealant, so it takes a bit of heat and a lot of patience and persistence to ge them off !!
