Author Topic: Rear brake caliper  (Read 2336 times)
andycuk71
  • Reading
Rear brake caliper
« on: 11 June 2007, 10:23:19 »
On my rear brake caliper the plunger on the inside of the disc is siezed and am unable to push back in to get the new shoes in outside of the disc is fine. any ideas how to unsieze or remove some of the pressure?
hotel21
  • The Kingdom of Fife
Re: Rear brake caliper
« Reply #1 on: 11 June 2007, 10:35:43 »
Tried opening the bleed valve a crack then levering the old pad/piston back in?  Its the better method, saves running the risk of popping seals back up the abs/master cyl and getting all the old crappy fluid out at the same time........
andycuk71
  • Reading
« Reply #2 on: 11 June 2007, 10:50:49 »
where is the bleed valve?
« Reply #3 on: 11 June 2007, 11:18:28 »
On the caliper - the one you use for bleeding the fluid :)
Martin_1962
« Reply #4 on: 11 June 2007, 11:46:43 »
Is it stiff or seized ?
stiff just a lot of constant force will eventually move it in. seized clamp off the pipe and remove the caliper, unless you want to risk filling the ABS controller with air.
Wood blocks are kindest to the disc and piston.
From here it depends how it fits or how it is stiff.
I am not suggesting my worst case fix (pump it out - not so good with ABS controllers), but vices and blocks of wood will help. As will twisting it.
Best preventative maintenance is hard braking, once overhauled I haven't had any braking problems with old cars once serviced, and I have replaced piston seals before.
andycuk71
  • Reading
« Reply #5 on: 11 June 2007, 14:13:16 »
got the caliper off what a oppsin nightmare and manages to get pistons back in what can I do to ensure they do not seize again?
Martin_1962
« Reply #6 on: 11 June 2007, 16:19:57 »
Occasional hard braking, thrashed brakes wear out but do not go wrong
« Reply #7 on: 11 June 2007, 16:21:45 »
I would say regular servicing would be better ;)
Martin_1962
« Reply #8 on: 11 June 2007, 20:19:09 »
It is gentle usage will kills calipers, heavy usage doeas help. Originally told this by my dad who is a retired mechanic.
« Reply #9 on: 11 June 2007, 21:05:11 »
Having had a few calipers lock up on works vehicles, trust me, heavy braking probably makes it worse.  Proper servicing is the best way....
Martin_1962
« Reply #10 on: 12 June 2007, 07:54:56 »
Don't know I have rebuilt a few in my time. My dad said that all the faulty brakes they had in were from too gentle usage and that is on all sorts of makes of cars (he was a mechanic for years - 1970s and some of 80s Peugeot - the ex Rootes palce stayed open my dad me first in and last out, then BMW until closure the Skoda & Subaru until retirement).
I work brakes quite hard and once fixed have never had a seized caliper since. THis is on bikes and cars.
