Author Topic: Bastard Bolt  (Read 3856 times)
Martin_1962
Bastard Bolt
« on: 09 June 2007, 15:08:34 »
Still can't get to it - really peeed off now, really annoying - my hands are too big!!!!
Ken T
  • Stockport
Re: Bastard Bolt
« Reply #1 on: 09 June 2007, 16:35:46 »
Which bolt is it ?. if all else fails a hammer and chisel !
Martin_1962
Re: Bastard Bolt
« Reply #2 on: 09 June 2007, 17:43:28 »
Coolant Transfer Pipe :(
Ronald_McBurger
Re: Bastard Bolt
« Reply #3 on: 10 June 2007, 05:26:50 »
I have looked at this bolt a lot and cannot see the problem really. To make it easy martin, syphon out the PAS reservoir and remove the hose then you get good acess to it.
Martin_1962
Re: Bastard Bolt
« Reply #4 on: 10 June 2007, 09:56:06 »
I moved it pushed the pipe down but had difficulty getting my hand in there
Re: Bastard Bolt
« Reply #5 on: 10 June 2007, 16:04:03 »
PM repled to mate, I'll get over as soon as I feasibly can
This bolt is reasonably easy with the PAS tank right out the way... the PAS pipe is a big hinderance...
Martin_1962
Re: Bastard Bolt
« Reply #6 on: 10 June 2007, 16:41:31 »
Thats the bugger but I can't get in there to do it.
As a model builder I can handle fiddly jobs but this is a right bugger.
As to one of your hates, if you want any discs done you know where I live, you hate doing them but I don't mind - that said I always get muddled on the rear shoes and do them the wrong way first, (been doing this since the Carlton)
Martin_1962
Re: Bastard Bolt
« Reply #7 on: 10 June 2007, 16:46:43 »
I had the same issue with DIS packs as well
Re: Bastard Bolt
« Reply #8 on: 10 June 2007, 17:13:09 »
My hates? Disks?
Martin_1962
Re: Bastard Bolt
« Reply #9 on: 10 June 2007, 21:55:34 »
My hates? Disks?
I remember you commenting you hated brakes
ians
  • Reading
Re: Bastard Bolt
« Reply #10 on: 10 June 2007, 22:01:16 »
Martin,
I have yet to do this job, but I did manage to get a spanner (10mm ring) on the bolt.  The spanner was horizontal pointing backwards towards the bulkhead.  I managed to get the fingers of my other hand on the head of the bolt to guide the spanner on and hold it there.  (Hope that makes some kind of sense..).
I know Chris (Clarce) used a ratchet spanner - I can see that would help as you don't have much room to swing the spanner.
Cheers
Ian
Martin_1962
Re: Bastard Bolt
« Reply #11 on: 10 June 2007, 22:17:44 »
When I tried a spanner it would not grip. :(
ians
  • Reading
Re: Bastard Bolt
« Reply #12 on: 10 June 2007, 22:34:54 »
is the bold still intact or has it been rounded off?
Sounds like moving the power steering reservoir is the next stop.
Re: Bastard Bolt
« Reply #13 on: 10 June 2007, 23:17:18 »
My hates? Disks?
I don't mind working on brakes at all - as long as it's on my own car. At this stage - I have a policy not to touch other people's brakes - just in case  ::) ::)
Martin_1962
Re: Bastard Bolt
« Reply #14 on: 11 June 2007, 11:11:06 »
My hates? Disks?
I'm quite happy to do that - done so many in the past I'm used to it.
