Author Topic: Radiator Removal  (Read 1726 times)
Dave-C
  • Staffordshire
  • The Old Girl
Radiator Removal
« on: 13 June 2007, 23:08:40 »
Has anyone removed a radiator on a 3.0l with air con and auto box.....  Is it awkward in any way?  thinking of changing mine as a matter of course...  Towing on the horizon!!!!  Gotta slow these bikes down, you know!!!!!!!!!! ;D ;D ;D ;D
Re: Radiator Removal
« Reply #1 on: 13 June 2007, 23:15:44 »
If no leaks or hot running, I really wouldn't bother.
Just do a cooling system flush with new VX antifreeze 50/50 mix.
To answer your question, the Rad is a dead easy job, on any of the Meega's.
« Reply #2 on: 14 June 2007, 00:07:06 »
If no leaks or hot running, I really wouldn't bother..............
Mmm! I can feel the high temp warning on my car again the next time I tow my 'van, normally everything is fine - doesn't really waver off 95 deg. If this persistant rain stops I'll be playing with my infra red thermometer and checking various bits of my radiator, time (& being 4r$ed  :o) permitting
« Reply #3 on: 14 June 2007, 02:28:27 »
On a T reg 3.0 - 95 deg totally normal
If you have access to the infa red though - would be interesting to have a play!
« Reply #4 on: 14 June 2007, 12:19:06 »
My MV6 normally runs about 92/93 when cruising, up to 95/96 in traffic before fans have a little chat...
Cruising at 95 seems a bit high to me...
« Reply #5 on: 14 June 2007, 12:34:34 »
When I said  Normal , perhaps I should have said solo ie without a 'van. Generally the temp with the 'van on was around 97/98 deg, it was just the long incline at 60mph that caused the temp to go high enough to put the high temp light on.
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #6 on: 14 June 2007, 17:51:50 »
Touche/  mine never went above 97 in the highlighted situation, until I flushed the system...  I'm asuming I/ve got a badly blocked rad...  have tried flusing it several times now, no change!!!   110k miles....  time for a new rad????? :'(
