Author Topic: mv6 failing to start - any ideas?  (Read 2690 times)
DJ_Brian
  • Horsham, West Sussex
« on: 13 June 2007, 18:31:23 »
One of those weeks!  A few nights ago, my mv6 3.2 started after cranking for about 5 secs, it normally fires up immediately.  I drove 50 miles, parked, an hour later it would not start.  Waited an hour, it fired up. :-?
Next day, car was fine.  Today, drove an hour, parked at work for 7hrs, car will not start. :'(
Any ideas before I call out the RAC?
Re: mv6 failing to start - any ideas?
« Reply #1 on: 13 June 2007, 18:33:56 »
You need to read the fault codes... I suspect crank sensor failing...
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #2 on: 13 June 2007, 18:35:19 »
Yep, basics first, do the electrics work - such as windows. Do you have dash lights?
Try to jump start it to eliminate the first obvious problem - the battery.
After this i suspect the usual suspect  ::)
« Reply #3 on: 13 June 2007, 18:37:02 »
If the engine is cranking fast - the battery won't be at fault...
DJ_Brian
« Reply #4 on: 13 June 2007, 18:50:22 »
Spot on, it spins but doesn't fire!
« Reply #5 on: 13 June 2007, 19:00:18 »
no flashing light on dash?
Markie
« Reply #6 on: 13 June 2007, 19:10:15 »
then as mentioned were looking at our friend the usual suspect  :-/ ;D
DJ_Brian
« Reply #7 on: 13 June 2007, 20:33:52 »
UPDATE!!!!
Well, our friendly RAC man has been and immediately suspects the crank sensor.  He did pull it out and clean it, but to no avail....Luckily this time the fault has gone hard, so I'm waiting for a shovel to recover the car back to my garage.
Thanks for the advice, this is a great place :y
« Last Edit: 13 June 2007, 20:34:29 by DJ_Brian »
« Reply #8 on: 13 June 2007, 20:48:00 »
UPDATE!!!!
Ha ha like it......as if cleaning a hall sensor will do owt!
Its the cable that fails due to heat anyway.....
« Reply #9 on: 14 June 2007, 13:02:11 »
Bless. In the words of Monty Python, an act of the purest optimism....
Guess I'd better get a spare for the tool kit if these are failing on 3.2s now...
cdx25
  • Plymouth, UK
« Reply #10 on: 14 June 2007, 13:10:35 »
 ;D ;D ;D
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
« Reply #11 on: 15 June 2007, 11:50:20 »
well one of the first things I bought for my 3.2 was a spare crank sensor, it's the boot ... ready and waiting  :y
« Reply #12 on: 15 June 2007, 12:17:43 »
Was that a genuine VX one or did you find an alternative source for a 3.2 one? I've seen them on Ebay but have heard there are various different connectors?
sounds2k
« Reply #13 on: 15 June 2007, 15:03:19 »
genuine Vx - there's only one for the 2.6 & 3.2, it's the same as the one fitted to the later 3.0's. P/N is 90540743, cost about £42 - but a worthwhile investment and will save waiting for one to arrive when (not if !!!) it fails ...
« Reply #14 on: 15 June 2007, 15:24:33 »
OK. Thanks for that. Will get one for the tool kit, and maybe a HBV too!
