Author Topic: Rear Shocks  (Read 2331 times)
Craig_R
  • Watford
Rear Shocks
« on: 15 June 2007, 18:10:53 »
Hiya Chaps
How hard Is it To change the rear shocks I have a set now I just need to put them on.
Do I need a compression tool of any kind.
Craig
Mod's
[To be Fitted]Reverse Sensors
Dazzler
  • Haverhill, Suffolk
Re: Rear Shocks
« Reply #1 on: 15 June 2007, 18:18:38 »
Piece of cake, no special tools, no need for spring compressors. 2 bolts 1 at the top inside the car and 1 underneath. Job done ;)
Craig_R
  • Watford
Re: Rear Shocks
« Reply #2 on: 15 June 2007, 18:48:17 »
Thanks I thought it was not to hard  :y :y
Craig
Mod's
Re: Rear Shocks
« Reply #3 on: 15 June 2007, 22:05:46 »
it is easy, as long as the lower bolts aren't seized. Stick penetrating oil on them before...
Timbuk
  • Telford
  • owned a Datsun 120y once!
Re: Rear Shocks
« Reply #4 on: 15 June 2007, 22:11:44 »
Did TheOlodians with him a month or two ago, they are very easy ;)
Admin
Re: Rear Shocks
« Reply #5 on: 15 June 2007, 23:03:09 »
As Jaime says.... if the bottom bolts release ok, then they are easy.
Spray lots of penetraing oil on them and say a silent prayer!  :)
The Administrator.
Craig_R
  • Watford
Re: Rear Shocks
« Reply #6 on: 16 June 2007, 15:00:11 »
Well Stuck penetrating oil onlast night and tried this morning to remove the bolts and not a dicky Brid no movment at all  >:(
I might not be strong enough need a wheely Gun Really to Shock Them off  >:(
Looks like Ill have to go to a garage to get them removed not a happy bunny
Mod's
hotel21
  • The Kingdom of Fife
Re: Rear Shocks
« Reply #7 on: 16 June 2007, 15:58:20 »
Plusgas, tightfitting ring spanner/six sided socket and tommy bar, used in conjunction with a good weight of Sid Snot lump hammer.
I normally give it a couple of skelps to tighten first as it seems to make them easier to unscrew afterwards.....   :y
Robin Hood
  • Nottingham
Re: Rear Shocks
« Reply #8 on: 16 June 2007, 17:00:07 »
When I did my rear adjustable they where so tight on the bottom having already removed the bolts, I had to hack saw the shock from the bush and remove the bush with a knife.  This just left the inner sleeve which I drilled and inserted a bar for more leverage.  Got there in the end but took a while.
