Author Topic: Headlamp Bulbs  (Read 4109 times)
Bo Bo
  • Coventry
Headlamp Bulbs
« on: 24 August 2006, 00:42:03 »
Due to shift work I have to do a lot of night driving & my headlights leave a lot to be desired.
I've tried a couple of xenon "upgrades", but to be honest although they looked good from the front, they were actually worse to drive with (espicially the blue ones).
I've done a bit of research & Ring Ultra Xenon seem to come up more than most.
So what's your views, what's the best wattage to go for & should you change the side light bulbs to match?
Cheers
« Last Edit: 24 August 2006, 00:42:21 by paulmccristall »
Markjay
  • London
Re: Headlamp Bulbs
« Reply #1 on: 24 August 2006, 00:45:11 »
Stick to 50W (not sure if the 80W and 100W are street legal anyway?), but go for the uprated '+50' bright light ones.
Alas, no more Omegas....
Re: Headlamp Bulbs
« Reply #2 on: 24 August 2006, 07:05:21 »
...... (not sure if the 80W and 100W are street legal anyway?).......
They're not, but who's gonna find out?
Re: Headlamp Bulbs
« Reply #3 on: 24 August 2006, 08:54:12 »
Your wiring........
Upgrade the headlight earth connections to.....
Re: Headlamp Bulbs
« Reply #4 on: 25 August 2006, 23:25:05 »
Your wiring........
Without going into current draw against the size of the wire etc etc I had no problems with my Manta that had 80(85?)/100W lamps in or my last Senator that had 100W in the driving/spot lamps. No problems with the Omega's HID headlights - one of it's redeeming features! (although I might look at 100W in the driving /spots)
Taxi_Driver
Re: Headlamp Bulbs
« Reply #5 on: 26 August 2006, 08:28:00 »
I agree....the +50 ones certainly make a difference, to the point where i'm just about happy with them now.
I was going to convert to HID's but its quite involved to do it correctly.
You could of course by a HID kit off ebay.....altho fitting these kits would still be illegal....as the kits ive seen dont make the headlight units auto tilt or have headlamp washers.
Cheers
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Headlamp Bulbs
« Reply #6 on: 26 August 2006, 08:36:15 »
Your wiring........
Like it.... ;D
I like red cars
Re: Headlamp Bulbs
« Reply #7 on: 26 August 2006, 10:39:38 »
The '+50' seem to be recommend, to the point that I would use them if I didn't have HIDs  :D
The 'Xenon' upgrade standard bulbs are worthless.
Bo Bo
  • Coventry
Re: Headlamp Bulbs
« Reply #8 on: 14 September 2006, 10:52:41 »
You're right, the Xenon standards are worthless & in the case of the blue ones I tried; actually worse.
I got the 50% brighter bulbs & there is an improvement, not brilliant but much better, although I wouldn't say they're 50% better!
