Author Topic: Knocking suspension  (Read 1619 times)
lipolad
Knocking suspension
« on: 17 June 2007, 10:55:26 »
Recently had the nearside wishbone replaced on my Omega Elite because it was rattling. The same noise appeared on the offside last week so I put the car in my local workshop and had the other one changed (I assumed that was the problem). I still have the  noise on the offside when going over the slightest uneven surface . During the week I will get the car jacked up and have a look. Do any of you have an idea of the probable cause.Is there another common suspension problem ?
Many thanks in advance
hotel21
  • The Kingdom of Fife
Re: Knocking suspension
« Reply #1 on: 17 June 2007, 11:00:37 »
Will probably be the anti roll bar droplinks.  See my similar post a few down from here as regards best deals/locations.  They are very straightforward to replace and, if totally rusted to bu**ery, simply hacksaw the old ones off then bolt up the new ones.  Straightforward!
HtH
B
oli3lv6
« Reply #2 on: 17 June 2007, 11:03:14 »
same problem on my elite it was droplink
DaveL
  • Nr. Cupar, Kingdom of Fife
« Reply #3 on: 17 June 2007, 11:12:50 »
Very common problem, have changed many on Carltons and also Fords. As Hotel 21 said easy peesy to do just make sure the nuts are tight on the connecting swivel or the fault will soon come back. I have found that with the use more of the ''speed bumps'' that the links fail on a regular basis.
Also check the suspension spring on the struts. again these break with the coil usually in a place that you cannot see i.e right at the top under the wing.
 8-)
DaveL
geoff
  • thornaby,stockton on tees
« Reply #4 on: 20 June 2007, 15:26:30 »
just done drop links on mine,you would not believe the amount of road noise these things actual stop,its now as quiet as a mouse,got mine for £9 each well cheap and only ten minutes a side wow! :y :y :y,also i think on todays roads and speed bumps they don't really last that long,my last pair lasted 3 years :y :y :y
« Last Edit: 20 June 2007, 15:28:16 by geoff »
