Author Topic: 3 Pipe Mod  (Read 1649 times)
wastedperfection
  • Stoke on Trent
3 Pipe Mod
« on: 20 June 2007, 16:31:13 »
Hi,
Been told that a common mod is the 3 pipe mod. Cant find anything about it on the net to do with an omega , but can find stuff about it on a vectra v6.
These are exactly the same engines arent they?
If so how do you do the 3 pipe mod?
Matt
Re: 3 Pipe Mod
« Reply #1 on: 20 June 2007, 16:53:33 »
Same power plant, different induction system and hence there is no 3 pipe mod on the Omega because on the vectra it involves buggering around with some resonance stubs around the airfilter and filter input pipe.
I have looked at it a few times on the Vectra and to be honest, I wouldn't bother as I cant see how it removes any restrictions.......
wastedperfection
  • Stoke on Trent
Re: 3 Pipe Mod
« Reply #2 on: 20 June 2007, 18:16:58 »
Oh right ok.
WOuld i get a noticable increase in torque or power if i drilled the airbox all around?
Or would it make mpg go down?
Matt
Jay w
  • Plymouth/Poole
  • omega gone
Re: 3 Pipe Mod
« Reply #3 on: 20 June 2007, 18:29:29 »
Oh right ok.
Matt
bear in mind that drilling the airbox will allow hot air back into the engine........
IT will sound good, but i doubt it will aid performance
Cone filters won't do much better either
