Author Topic: ecotec seal  (Read 6427 times)
Re: ecotec seal
« Reply #15 on: 21 June 2007, 22:27:00 »
i think i may have sorted it,just went and checked the car and low and behold the red light for the alarm/ immobiliser is not flashing (stereo one ok),after putting the key in the ignition and turning to position 1 i shut and opened the doors via the fob and then removed key and set alrm as normal and red light now flashing,cant start the car at the moment because the ecotec cover is still off, thanks 'the boy' for putting me on the right track with the immobiliser,will report back as soon as i fit the new seal,hopefully that will be that, quirky cars omegas!
Thanks for the update, and let us know how it goes :)
james171271
Re: ecotec seal
« Reply #16 on: 21 June 2007, 23:24:51 »
hi could you please post on here when you have managed to find the seal i too need one and was told by vauxhall it came as part of the ecotec unit at a cost of £74 + vat i tried asking autovaux and they never replied
cheers
mahony
  • london
    • omega elite 3.0
Re: ecotec seal
« Reply #17 on: 22 June 2007, 07:35:39 »
hopefully i will be able to find a seal without having to buy the whole ecotec/breather unit,if that's the case that you have to buy the whole set up i will repair the broken seal with super glue or start looking on ebay for omegas breaking, i wonder if the seal is the same on any other models ?,will report back on the flashing eml once the seals done. cheers for all the help chaps.
wakeyomega
  • Wakefield
Re: ecotec seal
« Reply #18 on: 22 June 2007, 08:37:05 »
When following the breather cleaning 'how to' in the maintenance guides (by Ronald McBurger), I saw this
You might want to consider repalcing the seals on the breather bridge section, details of these are as follows:
Breather bridge to plenum seal 1 off required - 90467543 90p+VAT each, retail
Breather bridge to throttle O ring 2 off required (4 off on extended plenums) - 90500983 43p+VAT each. retail
I took it that 90467543 was the seal you need. Perhaps Fin can confirm? or PM him (I also assumed the 2 O rings were for the two breather box ports that enter the throttle body)
Good Luck
Pat
Remember, if you ever need a helping hand, you'll find one at the end of your arm
mahony
  • london
    • omega elite 3.0
Re: ecotec seal
« Reply #19 on: 22 June 2007, 08:58:26 »
Thanks for that wakeyomega i did not spot that,it's a lot cheaper than £74 plus the vat,will ring vauxhall later and order all seals (i have the extended plenum).
Re: ecotec seal
« Reply #20 on: 22 June 2007, 14:12:35 »
cheers
Utter rubbish. Part no 90467543 for the little seal that fits between EcoTec box and plenum
mahony
  • london
    • omega elite 3.0
Re: ecotec seal
« Reply #21 on: 22 June 2007, 14:59:02 »
i can second that,just ordered mine from vauxhall £1.19p each,decided to get two and the other 'o' rings just in case.got to wait untill tuesday to pick them up though.
mahony
  • london
    • omega elite 3.0
Re: ecotec seal
« Reply #22 on: 22 June 2007, 16:16:58 »
Update,i repaired the ecotec to plenum seal with super glue,fired up the car and no more hissing,but the eml light was still flashing,i disconnected the battery and left for a hour,went back with the intention of doing the paper clip test,re- connected battery and no more flashing eml,hopefully it will stay that way.
Re: ecotec seal
« Reply #23 on: 22 June 2007, 16:20:43 »
Can you do a paperclip test anyway?
mahony
  • london
    • omega elite 3.0
Re: ecotec seal
« Reply #24 on: 22 June 2007, 16:26:52 »
Will do and report back.
mahony
  • london
    • omega elite 3.0
Re: ecotec seal
« Reply #25 on: 22 June 2007, 16:56:36 »
cant seem to get any codes up with engine running,am  i shorting the right pins 5+6 ? just found out it should be 4+6
« Last Edit: 22 June 2007, 17:04:52 by mahony »
mahony
  • london
    • omega elite 3.0
Re: ecotec seal
« Reply #26 on: 22 June 2007, 17:14:07 »
I shorted out two of the pins and got a spark! now the heater fans dont run and the radio is dead,help!
Dave-C
  • Staffordshire
  • The Old Girl
Re: ecotec seal
« Reply #27 on: 22 June 2007, 17:21:46 »
Check F16
Re: ecotec seal
« Reply #28 on: 22 June 2007, 17:26:50 »
I'm guessing you've counted wrong then!
Check Fuses...
mahony
  • london
    • omega elite 3.0
Re: ecotec seal
« Reply #29 on: 22 June 2007, 17:32:57 »
yep,found 20amp gone,going to leave well alone now,thanks for all the advice chaps. :y
