Author Topic: cam gaskets leak prevention.  (Read 1438 times)
Skanky
« on: 22 June 2007, 13:30:53 »
Just done my cam gaskets,   8-)
I have read on a forum , either here on VXON, that you can put a pipe from the oil filler cap that will prevent the gaskets blowing.
Has anyone done this "MOD" and is it worth doing ?
seems logical enough to me!!
Skanky  :y
Re: cam gaskets leak prevention.
« Reply #1 on: 22 June 2007, 15:20:57 »
Skanky  :y
No, just keep the breathers clean, that will prevent it ;)
« Reply #2 on: 22 June 2007, 15:35:32 »
Sounds like a daft idea to me.....
Consider this....
The breathers go to the inlet and the gases are mainly blow by gases i.e. exhaust fumes with a very small amount of oil vapour in them.
Add a tube to the oil filler and let air in and you have now created a path for un-metered air to get into the inlet i.e. an air leak......hence its a daft idea.
Keep the breathers clean and change the oil regularly......stop the cause of blocked breathers and you stop the engine pressurising....
Skanky
« Reply #3 on: 22 June 2007, 15:57:19 »
hmmmm if you put it that way, it is a daft idea!!!
VX1
  • Reading, Berkshire
« Reply #4 on: 22 June 2007, 17:47:14 »
Skanky  :y
Or you could just mear gasket seal over the head to cam cover, that works really well.
Vx Trade club card holder
Halfords trade card holder
« Reply #5 on: 22 June 2007, 17:50:32 »
Skanky  :y
When a new one is only a quid, is it worth it?
