Author Topic: 2.0 DOHC lumpy running  (Read 2124 times)
ians
  • Reading
« on: 23 June 2007, 14:31:40 »
My 2.0 has started running rough.
Symptons are
- does it all the time, hot or cold
- not pulling well.  Could be slightly better at high rpm but not convincing
- significant vibration at idle (7-800rpm), (and another resonance at 1500 most noticable when cold)
- no EML
Plugs are fairly new (<10k),  leads and dispack - who knows? probably original.
I removed plugs and the electrodes look good.
Airfilter fine and <10k
Fuel filter overdue  :-[ prob. 50k since last (Haynes says 40k replacement)
On investigation, plug wells are full of oil, so obviously need to replace the camcover seal again -previous one was Halfords before I was enlightened on here..
DIS pack looks bone dry. The car lives in a car port so I don't think water ingress is the issue.
I have cleaned out the plug wells and dried off the HT leads as best I can.  Problem remains.
Car is worth next to nothing ('94, 180k) so I don't really want to be throwing money at it at random.
I'm suspecting the HT leads are goosed, but I'd appreciate any suggestions.  I have a new fuel filter so prob most obvious to start with that.
Cheers,
Ian
VX1
  • Reading, Berkshire
Re: 2.0 DOHC lumpy running
« Reply #1 on: 23 June 2007, 15:24:09 »
Ian call me 07900447752.
Paul
Vx Trade club card holder
Halfords trade card holder
« Reply #2 on: 23 June 2007, 15:42:17 »
Firstly, cure the gasket, esle it will damaged the leads.
Also, change the fuel filter more regular - I do mine annually.
Martin_1962
« Reply #3 on: 23 June 2007, 18:27:07 »
Fix the gasket and replace the plug leads - the oil has probably broken the leads down.
Remember the 10 O-rings on the cam cover
gizza
  • baildon essex
« Reply #4 on: 23 June 2007, 21:03:32 »
if your doing the gasket clean out the breathers and throttle body while your in there mine was doing simular things to yours but i cleaned and replaced breathers and the throttle body and runs sweet as a nut now
