Author Topic: Steering Box Question  (Read 1958 times)
Craig_R
  • Watford
« on: 24 June 2007, 11:43:01 »
Hiya Chaps
After Speaking To James last weekend he said that the knock in my Steering Is likely to be my Steering Box
Has Anyone changed One ? if so how hard is it ?
Can anyone with a Haynes manual scan in the section on removing a steering box just so i can see how much of a pig of a job it might be if i decided to go that route. I dont want to buy a Haynes manual as everyone says the book is rubbish
Craig
Mod's
[To be Fitted]Reverse Sensors
Re: Steering Box Question
« Reply #1 on: 24 June 2007, 12:03:35 »
Hiya Chaps
Craig
The book is worth having, as it is a useful guide still, even if a bit naff in places.  Pick up a cheapy of ebay for around a fiver, as £20 from Halfords is a tad dear...
No idea if it covers steering box though...
« Last Edit: 24 June 2007, 12:04:13 by TheBoy »
« Reply #2 on: 24 June 2007, 12:39:16 »
There is also an adjustment on the steering box. If you haven't already tried it it might be worth a go before you change it.
The Barge Captain
« Reply #3 on: 24 June 2007, 13:22:57 »
Fairly sure Haynes doesn't cover the steering box, but don't quote me on that.
Taxi_Driver
« Reply #4 on: 24 June 2007, 19:08:03 »
If youve got a Halfords Trade card it comes down to £12 or £14 (carnt remember  :-[ )
Where you going to the Tidworth meet Craig? If so I could get you one and bring it with me  :y
Craig_R
  • Watford
« Reply #5 on: 24 June 2007, 19:36:24 »
Thnaks TD But its OK if the Steering Box is not in it ill not bother
Yeah I think ill be there next weekend I have just PM Gaffey to ask for the address and give him my Info
I am in two minds if it is the Steering Box Or Not Guess with a bit of investigation next weekend and the use of a pit ill find out
Craig
Mod's
mv6copcar
  • Essex, Halstead
« Reply #6 on: 24 June 2007, 20:10:13 »
Yes try the above first. i had knocking and a lot of play in my rack - adjusted the nut on the box and it sorted me right out.
someone else will tell you i'm sure-but IIRC its a 18mm nut with a torx bolt in the middle. but only adjust 1/16th of a turn at a time.
HTH
Craig_R
  • Watford
« Reply #7 on: 24 June 2007, 20:53:02 »
Done The tighten by 1/16th 1/8th last weekend did not help TB said i might of tightened it when not needed I put it back to what it was but no difference it may need more tightening but i dont want to over do it and knack it to the pont of not working safely
Craig
Mod's
Timbuk
  • Telford
  • owned a Datsun 120y once!
« Reply #8 on: 24 June 2007, 21:06:13 »
' Steering Gear ' is covered in Haynes but is not brilliant :-/
